Memory Maps LOAD SAVE
I am using a Dallas 390 in continous mode and I am trying to store configuration memory using the simulator LOAD and SAVE commands.
To save the memory map I am using the following command
SAVE bbram.HEX X:0x100000, X:0x107FF8
This appears to save the data from the memory map into an intel hex file as I expected. But when I use the following load command to reload the memory map it appears to do nothing.
LOAD bbram.HEX
Anyone know what I am doing wrong ?
