I am emulating a code based on the I2C slave application note from Philips. What happens is my the microcontroller (LPC762)start locking the bus as soon as the I2C slave functions get activated by setting I2CFG register to slave or a master configuration (values 9xh or 8xh). I don't know what the micro is doing to the I2C bus (which seems to have the SDA and SCL high though). The bus stops responding to query from a different master right after excuting the "mov I2CFG, #80h" instruction. Am I missing anything to configure before setting the I2CFG register in the code below: ;
Main program ;----------------------------------------------------------------------------- Reset: mov SP, #2Fh ; Set stack location mov R0, #TxData ; Set up pointer to Tx data area mov R1, #MaxBytes ; Set up buffer lenght counter RLoop: mov @R0, #0FFh ; Initialize buffer memory to 1's inc R0 ; Advance to next buffer position djnz R1, RLoop ; Repeat untill done ; Initialize comparator 1 and 2 ;------------------------------------------------ ; Comparators have to start up for at ; least 10us before use. The 10 us delay is ; garanteed by the instrcutions cycle time ; running after enabling the comparators ;------------------------------------------------ CmpInit: mov PT0AD, #14h ; Disable digital inputs on CIN1A and CIN2A ;anl P0M2, #0cfh ; Disable digital outputs ;orl P0M1, #30h mov CMP1, #28h ; Turn on comp 1 mov CMP2, #28h ; Turn on comp 2 anl CMP1, #0feh ; clear comp 1 interrupt flag anl CMP2, #0feh ; clear comp 2 interrupt flag clr EC1 ; disable comp 1 interrupt clr EC2 ; disable comp 2 interrupt mov P1M1, #02h ; Set pin 1 in port 1 to input only mode mov P1M2, #00h ; other port 1 pins to Quasi-bidirectional mode ; Fill in the Expanders address table ;---------------------------------------------- mov ExpTable, #Exp1_Add mov ExpTable + 1, #Exp2_Add mov ExpTable + 2, #Exp3_Add mov ExpTable + 3, #Exp4_Add mov ExpTable + 4, #Exp5_Add mov ExpTable + 5, #Exp6_Add mov ExpTable + 6, #Exp7_Add mov ExpTable + 7, #ExpVM_Add ; Set up interrupts ;---------------------------------------------- mov AdrRcvd, #0 ; Clear address received mov Flags, #0 ; Clear system flags setb EI2 ; Enable I2C interrupt setb ETI ; Enable Timer 1 interrupt setb EA ; Enable interrupt system mov I2CFG, #BSLAV+CTVAL ; Enable slave functions = 80h mov I2CON, #BCSTR+BCSTP+BCXA+BCDR+BCARL+BIDLE ; Put slave into idle mode setb TIRUN ; Turn on Timer I ; Main Loop ;---------------------------------------------- MainLoop: ajmp
Have you tried the existing Keil I2C example program for the LPC devices? http://www.keil.com/download/docs/lpc_i2c.zip.asp Jon
I did configure my register the same way almost(well I'm using the micro as a slave in my case) but it still doesn't work. the micro is doing something wierd when I2CFG register is set.
