XC16CJ three questions
I have three questions regarding Infineon microcontroller C161CJ:
1) Is it fully supported by KEIL?
2) It has OCDS : On chip Debug Support.
Can KEIL software use this? If so Is there any information regarding the cable connections to the PC?
3) It has a flash memory.
Does anyone on this Forum has ever used? I am with the usual problems of very little time to do the hardware and the software and I would like to know if someone has already made some code to write parameters on the internal flash. I do not know if it is troublesome or not! If so I might think on using one external SEEPROM:)
Thanks All & Best regards,
Joao
  • 1) Is it fully supported by KEIL?
    Yep.
    Yep. You can use ULINK (http://www.keil.com/ulink) to do that. I am in the process of adding details on that to the web site. It will be up by Monday.
    Jon
  • Thanks Jon,
    I Have sent the requset for this to our logistic department.
    I am completing the schematic and really need to know what connections shall I put in my board to connect to the ulink cable.
    Can you give me details about the circuit for the OCDS.
    Is it? - from Infineon ap24001.pdf:
    The connector is a standard 2.54 mm (0.1 inch) centres.
    TMS 1 - 2 VDD
    TDO 3 - 4 GND
    CPU_CLOCK 5 - 6 GND
    TDI 7 - 8 RESET
    TRST 9 - 10 BRKOUT
    TCK 11 - 12 GND
    BRKIN 13 - 14 OCDSE
    RCAP1 15 - 16 RCAP2
    WITH :
    The following signals should be connected to pull-ups pull-downs of 10 kΩ respectively
    on the cpu board.
    – OCDS, TMS, TCK, TDI, TRST, RESET, BRKIN
    Also I am not placing external RAMs on board.
    Is it ok for ulink? That is it can run only with the microcontroller?
    Any other circuit requirements?
    Thanks,
    Joao
  • I need to know this information as well. Can anyone help?
    Walt
  • This information is in the C166 Version 4.24 on-line help. Download the current eval version from http://www.keil.com/demo and take a look to Keil\C166\HLP\OCDS.CHM - OCDS Connector Pinout.
