Hi I want to use the second data pointer available in Dallas, since i am reading my port and then immediatly writing this data to external ram.All this has to be done in ISR in 10us. I am using in line assembly but the code is not working when i use both data pointers. void external0(void) interrupt 0 using 1 { //TRACK1[LEN_TRK1++]=XBYTE[0x8000]; //TRACK1[LEN_TRK1++] = XBYTE[0x8001]; //The above two C statements are replaced by the below mentioned Assembly code #pragma ASM SETB DPS ; DPS=1 ACTIVE DPTR1 MOV DPTR,#08000H MOVX A,@DPTR ; READ INC DPTR CLR DPS ; DPS=0 ACTIVE DPTR0 MOV DPL,LEN_TRK1+01H MOV DPH,LEN_TRK1 MOVX @DPTR,A ; WRITE INC DPTR SETB DPS ; DPS=1 ACTIVE DPTR1 MOVX A,@DPTR ; READ CLR DPS ; DPS=0 ACTIVE DPTR0 MOVX @DPTR,A ; WRITE INC DPTR MOV LEN_TRK1+01H,DPL MOV LEN_TRK1,DPH #pragma ENDASM } Thanx Faisal
Looking at your assembly code you are using the statements clr dps & setb dps but the dps register is a byte not a bit. As far as I recall the DPS register is not bit addressable so you cannot set and clear the SEL bit within it directly. Dallas recommended using the inc dps instruction to flip back and forth between the dptrs. Of course you have to start by initialising it to a known value.
Doh Glad to hear I am an authorised user. Sorry, I didn't mean to be anonymous.
I am not using Reg520.h but reg51.h, and i have defined DPS as sbit. sbit DPS=0x86;
Am I missing something. You can define DPS as a bit at 0x86h if you like but that won't cause Dallas to change the hardware! Surely, 0x86h is the location of the bit 6 of the port zero latch in all variants of the 8031 series.
Yes peter you are right. i have now defined DPS as sfr and have used mov dps,#01H to achieve my objective and its working now. Thanx for your help Faisal
Faisal Glad to hear 'it's working' the other trap you can fall into with these dual dptr is saving and restoring the context in an interrupt routine. If you are using both dptrs within the ISR you need to pop & push both dptrs not just one. Although I suppose if only a single ISR uses the 2nd dptr you can get away with it. On the other hand that could be creating a hole that you can fall into later when you start using the 2nd dptr in other parts of the code.
Yes i am using this 2nd dptr in both the ISRs of external INT0 and INT1. but i am not saving this dptr2 in both ISRs. Since push and pop will take a lot of time and will make the use of this 2nd dptr ineffective. (right now i have achieved 36% speed advantage over C code). However results of my hardware are fine. I think this is bcz i am not using dptr2 anywhere else and second in both ISRs when i am going to use this dptr2 i first load it with a new value like 0x8000 etc.then i use it. What do u think of this configuration can it become a source of error. thanx Faisal
Thoughts I guess both your INT0 & INT1 interrupts are set at the same priority. Therefore when one is running it will block out the other and there will be no conflict. "What do u think of this configuration can it become a source of error." Well this was my concerned; yes it can become a source error if, at a later date, you or another programmer starts using the 2nd dptr in the main code or changes the priority level of one of the ISRs. You must decided for yourself what is most important compact fast code or code that allows for future changes. Of course you can always insert a note in the source that the ISR doesn't save the 2nd dptr and therefore this cannot be used in other routines and the priority level of the ISRs must be preserved.
You might want to try to writing your idea using C.
#include <REG530.H> //#pragma nomoddp2 //don't use this, causes extra code??? char xdata* pTrk1; char xdata Port _at_ 0x8000; void external0(void) interrupt 0 //using just adds extra code { register char xdata* dptr; dptr = pTrk1; DPS++; ACC = *dptr; dptr++; DPS++; *dptr = ACC; dptr++; DPS++; ACC = *dptr; DPL1--; DPS++; *dptr = ACC; dptr++; pTrk1 = dptr; } void main(void) { DPH1 = 0x8000 >> 8; DPL1 = 0x8000 & 0xFF; }
; FUNCTION external0 (BEGIN) 0000 C0E0 PUSH ACC 0002 C083 PUSH DPH 0004 C082 PUSH DPL ; SOURCE LINE # 9 ; SOURCE LINE # 12 ;---- Variable 'dptr' assigned to Register 'DPTR' ---- 0006 850082 R MOV DPL,pTrk1+01H 0009 850083 R MOV DPH,pTrk1 ; SOURCE LINE # 14 000C 0586 INC DPS ; SOURCE LINE # 15 000E E0 MOVX A,@DPTR ; SOURCE LINE # 16 000F A3 INC DPTR ; SOURCE LINE # 18 0010 0586 INC DPS ; SOURCE LINE # 19 0012 F0 MOVX @DPTR,A ; SOURCE LINE # 20 0013 A3 INC DPTR ; SOURCE LINE # 23 0014 0586 INC DPS ; SOURCE LINE # 24 0016 E0 MOVX A,@DPTR ; SOURCE LINE # 25 0017 1584 DEC DPL1 ; SOURCE LINE # 27 0019 0586 INC DPS ; SOURCE LINE # 28 001B F0 MOVX @DPTR,A ; SOURCE LINE # 29 001C A3 INC DPTR ; SOURCE LINE # 31 001D 858300 R MOV pTrk1,DPH 0020 858200 R MOV pTrk1+01H,DPL ; SOURCE LINE # 32 0023 D082 POP DPL 0025 D083 POP DPH 0027 D0E0 POP ACC 0029 32 RETI ; FUNCTION external0 (END)
Welcome Jon. Glad to see a better C expert than me pitching in and raising to the challenge of 'right now I have achieved 36% speed advantage over C code'
I have 2 suggestions. I think both of them will generate FASTER code that is more portable and easier to understand. Neither uses dual data pointers and here's why. 1. There are 2 DPTR loads required. There is no difference between loading DPTR1 and DPTR2 and loading DPTR1 2 times. (Except that if we only use 1 data pointer, we don't have to have the instruction to switch data pointers.) 2. There is no reason to read only 1 byte, switch data pointers, write it, switch data pointers, read another byte, switch pointers, and write. We can load DPTR1, read 2 bytes, load DPTR1, and write 2 bytes. 3. The real confusion I had was that the original comments don't match the code that is provided. While the following comment:
18 extern unsigned char xdata *pTrack1; 19 20 void external0(void) interrupt 0 using 1 21 { 22 1 //TRACK1[LEN_TRK1++]=XBYTE[0x8000]; //TRACK1[LEN_TRK1++] = XBYTE[0x8001]; 23 1 24 1 *((unsigned int xdata *)pTrack1) = *((unsigned int xdata *) (0x8000)); 25 1 pTrack1 += 2; 26 1 } . . . ; FUNCTION external0 (BEGIN) 0000 C0E0 PUSH ACC 0002 C083 PUSH DPH 0004 C082 PUSH DPL 0006 C0D0 PUSH PSW 0008 75D008 MOV PSW,#08H ; SOURCE LINE # 20 ; SOURCE LINE # 24 000B 908000 MOV DPTR,#08000H 000E E0 MOVX A,@DPTR 000F FF MOV R7,A 0010 A3 INC DPTR 0011 E0 MOVX A,@DPTR 0012 850082 E MOV DPL,pTrack1+01H 0015 850083 E MOV DPH,pTrack1 0018 CF XCH A,R7 0019 F0 MOVX @DPTR,A 001A A3 INC DPTR 001B EF MOV A,R7 001C F0 MOVX @DPTR,A ; SOURCE LINE # 25 001D 7402 MOV A,#02H 001F 2500 E ADD A,pTrack1+01H 0021 F500 E MOV pTrack1+01H,A 0023 E4 CLR A 0024 3500 E ADDC A,pTrack1 0026 F500 E MOV pTrack1,A ; SOURCE LINE # 26 0028 D0D0 POP PSW 002A D082 POP DPL 002C D083 POP DPH 002E D0E0 POP ACC 0030 32 RETI ; FUNCTION external0 (END)
5 extern unsigned char xdata Track1[]; 6 extern unsigned char data LEN_TRK1; 7 8 void external0(void) interrupt 0 using 1 9 { 10 1 //TRACK1[LEN_TRK1++]=XBYTE[0x8000]; //TRACK1[LEN_TRK1++] = XBYTE[0x8001]; 11 1 12 1 *((unsigned int xdata *) &Track1[LEN_TRK1]) = *((unsigned int xdata *) (0x8000)); 13 1 LEN_TRK1 += 2; 14 1 } 15 . . . ; FUNCTION external0 (BEGIN) 0000 C0E0 PUSH ACC 0002 C083 PUSH DPH 0004 C082 PUSH DPL 0006 C0D0 PUSH PSW 0008 75D008 MOV PSW,#08H ; SOURCE LINE # 8 ; SOURCE LINE # 12 000B 908000 MOV DPTR,#08000H 000E E0 MOVX A,@DPTR 000F FE MOV R6,A 0010 A3 INC DPTR 0011 E0 MOVX A,@DPTR 0012 FF MOV R7,A 0013 7400 E MOV A,#LOW Track1 0015 2500 E ADD A,LEN_TRK1 0017 F582 MOV DPL,A 0019 E4 CLR A 001A 3400 E ADDC A,#HIGH Track1 001C F583 MOV DPH,A 001E EE MOV A,R6 001F F0 MOVX @DPTR,A 0020 A3 INC DPTR 0021 EF MOV A,R7 0022 F0 MOVX @DPTR,A ; SOURCE LINE # 13 0023 0500 E INC LEN_TRK1 0025 0500 E INC LEN_TRK1 ; SOURCE LINE # 14 0027 D0D0 POP PSW 0029 D082 POP DPL 002B D083 POP DPH 002D D0E0 POP ACC 002F 32 RETI ; FUNCTION external0 (END)
#define ORIGINAL 1 //#define CASE1 1 //#define CASE2 1 #ifdef ORIGINAL #pragma SRC #endif #include <REG530.H> #ifdef CASE2 extern unsigned char xdata Track1[]; extern unsigned char data LEN_TRK1; void external0(void) interrupt 0 using 1 { //TRACK1[LEN_TRK1++]=XBYTE[0x8000]; //TRACK1[LEN_TRK1++] = XBYTE[0x8001]; *((unsigned int xdata *) &Track1[LEN_TRK1]) = *((unsigned int xdata *) (0x8000)); LEN_TRK1 += 2; } #elif defined(CASE1) extern unsigned char xdata *pTrack1; void external0(void) interrupt 0 using 1 { //TRACK1[LEN_TRK1++]=XBYTE[0x8000]; //TRACK1[LEN_TRK1++] = XBYTE[0x8001]; *((unsigned int xdata *)pTrack1) = *((unsigned int xdata *) (0x8000)); pTrack1 += 2; } #else extern unsigned char xdata LEN_TRK1[]; void external0(void) interrupt 0 using 1 { #pragma ASM SETB DPS ; DPS=1 ACTIVE DPTR1 MOV DPTR,#08000H MOVX A,@DPTR ; READ INC DPTR CLR DPS ; DPS=0 ACTIVE DPTR0 MOV DPL,LEN_TRK1+01H MOV DPH,LEN_TRK1 MOVX @DPTR,A ; WRITE INC DPTR SETB DPS ; DPS=1 ACTIVE DPTR1 MOVX A,@DPTR ; READ CLR DPS ; DPS=0 ACTIVE DPTR0 MOVX @DPTR,A ; WRITE INC DPTR MOV LEN_TRK1+01H,DPL MOV LEN_TRK1,DPH #pragma ENDASM } #endif
Hi The C code written by both jon's is really impressive. There are certain points which are ambiguous on my part which i should clear. 1. The assembly code in my original query is not the one generated for the commented C code instead it is the one i am adding instead of the C code using in line assembly. 2. The orignal C code and its equivalent asm code generated are xdata unsigned char TRACK1[0x2000];//Track1 buffer is located in first 8k locations of ext ram unsigned int LEN_TRK1;//This has to be int as the data received is in excess of 5k void external0(void) interrupt 0 using 1 { STG2_PST_TRK1 = 0; TR0 = 0; if(CNT_EN2_TRK1==1) { TRACK1[LEN_TRK1++] = XBYTE[0x8000]; TRACK1[LEN_TRK1++] = XBYTE[0x8001]; CNTR1_RST_TRK1 = 1; CNTR1_RST_TRK1 = 0; } else { TRACK1[LEN_TRK1++] = XBYTE[0x8002]; TRACK1[LEN_TRK1++] = XBYTE[0x8003]; CNTR2_RST_TRK1 = 1; CNTR2_RST_TRK1 = 0; } 0000 C0E0 PUSH ACC 0002 C083 PUSH DPH 0004 C082 PUSH DPL 0006 C0D0 PUSH PSW 0008 75D008 MOV PSW,#08H ; 000B C292 CLR STG2_PST_TRK1 C28C CLR TR0 ; 000F 30933C JNB CNT_EN2_TRK1,?C0012 ; SOURCE LINE # 194 0012 908000 MOV DPTR,#08000H 0015 E0 MOVX A,@DPTR 0016 FF MOV R7,A 0017 0500 R INC LEN_TRK1+01H 0019 E500 R MOV A,LEN_TRK1+01H 001B AC00 R MOV R4,LEN_TRK1 001D 7002 JNZ ?C0100 001F 0500 R INC LEN_TRK1 0021 ?C0100: 0021 14 DEC A 0022 2400 R ADD A,#LOW TRACK1 0024 F582 MOV DPL,A 0026 7400 R MOV A,#HIGH TRACK1 0028 3C ADDC A,R4 0029 F583 MOV DPH,A 002B EF MOV A,R7 002C F0 MOVX @DPTR,A ; SOURCE LINE # 195 002D 908001 MOV DPTR,#08001H 0030 E0 MOVX A,@DPTR 0031 FF MOV R7,A 0032 0500 R INC LEN_TRK1+01H 0034 E500 R MOV A,LEN_TRK1+01H 0036 AC00 R MOV R4,LEN_TRK1 0038 7002 JNZ ?C0101 003A 0500 R INC LEN_TRK1 003C ?C0101: 003C 14 DEC A 003D 2400 R ADD A,#LOW TRACK1 003F F582 MOV DPL,A 0041 7400 R MOV A,#HIGH TRACK1 0043 3C ADDC A,R4 0044 F583 MOV DPH,A 0046 EF MOV A,R7 0047 F0 MOVX @DPTR,A ; 0048 D290 SETB CNTR1_RST_TRK1 ; 004A C290 CLR CNTR1_RST_TRK1 ; 004C 803A SJMP ?C0013 004E ?C0012: ; ; SOURCE LINE # 201 004E 908002 MOV DPTR,#08002H 0051 E0 MOVX A,@DPTR 0052 FF MOV R7,A 0053 0500 R INC LEN_TRK1+01H 0055 E500 R MOV A,LEN_TRK1+01H 0057 AC00 R MOV R4,LEN_TRK1 0059 7002 JNZ ?C0102 005B 0500 R INC LEN_TRK1 005D ?C0102: 005D 14 DEC A 005E 2400 R ADD A,#LOW TRACK1 0060 F582 MOV DPL,A 0062 7400 R MOV A,#HIGH TRACK1 0064 3C ADDC A,R4 0065 F583 MOV DPH,A 0067 EF MOV A,R7 0068 F0 MOVX @DPTR,A ; SOURCE LINE # 202 0069 908003 MOV DPTR,#08003H 006C E0 MOVX A,@DPTR 006D FF MOV R7,A 006E 0500 R INC LEN_TRK1+01H 0070 E500 R MOV A,LEN_TRK1+01H 0072 AC00 R MOV R4,LEN_TRK1 0074 7002 JNZ ?C0103 0076 0500 R INC LEN_TRK1 0078 ?C0103: 0078 14 DEC A 0079 2400 R ADD A,#LOW TRACK1 007B F582 MOV DPL,A 007D 7400 R MOV A,#HIGH TRACK1 007F 3C ADDC A,R4 0080 F583 MOV DPH,A 0082 EF MOV A,R7 0083 F0 MOVX @DPTR,A ; 0084 D291 SETB CNTR2_RST_TRK1 ; 0086 C291 CLR CNTR2_RST_TRK1 ; 0088 ?C0013: ; 0088 D292 SETB STG2_PST_TRK1 ; 008A 758A00 MOV TL0,#00H ; 008D 758C4C MOV TH0,#04CH ; 0090 D28C SETB TR0 ; 0092 750000 R MOV ovf_count,#00H ; 0095 D0D0 POP PSW 0097 D082 POP DPL 0099 D083 POP DPH 009B D0E0 POP ACC 009D 32 RETI Now as u can see the asm code generated is wasteful. The real prob is with ram read/write ops others have 1 to 1 correspondence. So i need to ge after these ram ops and boost them. Thanx Faisal
Faisal, I'm using C51 V7, so my results will probably be a little different. 1. There are still some undefined variables in your program. I assumed they are unsigned char data. 2. The size of your function is 152 bytes. 3. The size of my function (modified as explained in my previous post) is 105 bytes. A difference of 47 bytes. I'm pretty sure it runs faster, too. Here it is:
36 void external0(void) interrupt 0 using 1 37 { 38 1 STG2_PST_TRK1 = 0; 39 1 TR0 = 0; 40 1 41 1 if(CNT_EN2_TRK1==1) 42 1 { 43 2 *((unsigned int xdata *) &TRACK1[LEN_TRK1]) = *((unsigned int xdata *) (0x8000)); 44 2 CNTR1_RST_TRK1 = 1; 45 2 CNTR1_RST_TRK1 = 0; 46 2 } 47 1 else 48 1 { 49 2 *((unsigned int xdata *) &TRACK1[LEN_TRK1]) = *((unsigned int xdata *) (0x8002)); 50 2 CNTR2_RST_TRK1 = 1; 51 2 CNTR2_RST_TRK1 = 0; 52 2 } 53 1 54 1 LEN_TRK1 += 2; 55 1 }
; FUNCTION external0 (BEGIN) 0000 C0E0 PUSH ACC 0002 C083 PUSH DPH 0004 C082 PUSH DPL 0006 C0D0 PUSH PSW 0008 75D008 MOV PSW,#08H ; SOURCE LINE # 36 ; SOURCE LINE # 38 000B 750000 R MOV STG2_PST_TRK1,#00H ; SOURCE LINE # 39 000E C28C CLR TR0 ; SOURCE LINE # 41 0010 E500 R MOV A,CNT_EN2_TRK1 0012 B40121 CJNE A,#01H,?C0001 ; SOURCE LINE # 42 ; SOURCE LINE # 43 0015 908000 MOV DPTR,#08000H 0018 E0 MOVX A,@DPTR 0019 FE MOV R6,A 001A A3 INC DPTR 001B E0 MOVX A,@DPTR 001C FF MOV R7,A 001D 7400 R MOV A,#LOW TRACK1 001F 2500 R ADD A,LEN_TRK1+01H 0021 F582 MOV DPL,A 0023 7400 R MOV A,#HIGH TRACK1 0025 3500 R ADDC A,LEN_TRK1 0027 F583 MOV DPH,A 0029 EE MOV A,R6 002A F0 MOVX @DPTR,A 002B A3 INC DPTR 002C EF MOV A,R7 002D F0 MOVX @DPTR,A ; SOURCE LINE # 44 002E 750001 R MOV CNTR1_RST_TRK1,#01H ; SOURCE LINE # 45 0031 750000 R MOV CNTR1_RST_TRK1,#00H ; SOURCE LINE # 46 0034 801F SJMP ?C0002 0036 ?C0001: ; SOURCE LINE # 48 ; SOURCE LINE # 49 0036 908002 MOV DPTR,#08002H 0039 E0 MOVX A,@DPTR 003A FE MOV R6,A 003B A3 INC DPTR 003C E0 MOVX A,@DPTR 003D FF MOV R7,A 003E 7400 R MOV A,#LOW TRACK1 0040 2500 R ADD A,LEN_TRK1+01H 0042 F582 MOV DPL,A 0044 7400 R MOV A,#HIGH TRACK1 0046 3500 R ADDC A,LEN_TRK1 0048 F583 MOV DPH,A 004A EE MOV A,R6 004B F0 MOVX @DPTR,A 004C A3 INC DPTR 004D EF MOV A,R7 004E F0 MOVX @DPTR,A ; SOURCE LINE # 50 004F 750001 R MOV CNTR2_RST_TRK1,#01H ; SOURCE LINE # 51 0052 750000 R MOV CNTR2_RST_TRK1,#00H ; SOURCE LINE # 52 0055 ?C0002: ; SOURCE LINE # 54 0055 7402 MOV A,#02H 0057 2500 R ADD A,LEN_TRK1+01H 0059 F500 R MOV LEN_TRK1+01H,A 005B E4 CLR A 005C 3500 R ADDC A,LEN_TRK1 005E F500 R MOV LEN_TRK1,A ; SOURCE LINE # 55 0060 D0D0 POP PSW 0062 D082 POP DPL 0064 D083 POP DPH 0066 D0E0 POP ACC 0068 32 RETI ; FUNCTION external0 (END)
I think this discussion has lost the woods for the cause of the tree. When copying a byte or two, very little time spent either way and it is easy to make the two approaches (almost) equally fast. If you are copying, say, 112 bytes from one place to another (I do, as part of a string reformatting routine) it is definitely faster to use 2 data pointers, than the code from the compiler.
loop: movx a,@dptr inc dptr ; do something to the accumulator inc auxr movx @dptr,a inc dptr inc auxr djnz r7,loop
A long time ago, I profiled the execution performance of the dual data pointers on the Dallas 320. I think that the break-even is somewhere around 5-6 bytes. That's why I tried to point out that using dual data pointers for only 2 bytes is overly complex and doesn't gain anything. For larger buffers, I agree that dual data pointers speed things up. Jon
