using 2nd DPTR in DS87C520
Hi
I want to use the second data pointer available in Dallas, since i am reading my port and then immediatly writing this data to external ram.All this has to be done in ISR in 10us. I am using in line assembly but the code is not working when i use both data pointers.
void external0(void) interrupt 0 using 1
//TRACK1[LEN_TRK1++]=XBYTE[0x8000]; //TRACK1[LEN_TRK1++] = XBYTE[0x8001];
//The above two C statements are replaced by the below mentioned Assembly code
#pragma ASM
SETB DPS ; DPS=1 ACTIVE DPTR1
MOV DPTR,#08000H
MOVX A,@DPTR ; READ
INC DPTR
CLR DPS ; DPS=0 ACTIVE DPTR0
MOV DPL,LEN_TRK1+01H
MOV DPH,LEN_TRK1
MOVX @DPTR,A ; WRITE
INC DPTR
MOVX A,@DPTR ; READ
INC DPTR
MOV LEN_TRK1+01H,DPL
MOV LEN_TRK1,DPH
#pragma ENDASM
Thanx
Faisal
  • "I think this discussion has lost the woods for the cause of the tree."
    Well yes Erik, but lets be more positive Jon & Jon took the discussion off on a second and interesting line by 'raising to the challenge'.
    I wouldn't disagree with JW that the break-even point is around 5 or 6 bytes.
    Efficient and complete C code for an application that can benefit from dual dptrs is another point. We don't necessarily have to answer every point the original question could rise; not that I wish to stop anybody raising to that challenge.
    In my mind there is also still the question -
    Will the compiler handle the problem of saving the context (i.e. pushing both dptrs) in an ISR. I suspect not but don't have time to investigate at the moment.
  • To see the worst case "context saving", just put in an external fn call.
    If you set the "use dual dptr" option, you get:
    extern void fn(void);
        fn();
                 ; FUNCTION external0 (BEGIN)
    0000 C0E0              PUSH    ACC
    0002 C0F0              PUSH    B
    0004 C083              PUSH    DPH
    0006 C082              PUSH    DPL
    0008 C085              PUSH    DPH1
    000A C084              PUSH    DPL1
    000C C086              PUSH    DPS
    000E 758600            MOV     DPS,#00H
    0011 C0D0              PUSH    PSW
    0013 75D008            MOV     PSW,#08H
                                               ; SOURCE LINE # 11
                                               ; SOURCE LINE # 13
    0016 120000      E     LCALL   fn
                                               ; SOURCE LINE # 14
    0019 D0D0              POP     PSW
    001B D086              POP     DPS
    001D D084              POP     DPL1
    001F D085              POP     DPH1
    0021 D082              POP     DPL
    0023 D083              POP     DPH
    0025 D0F0              POP     B
    0027 D0E0              POP     ACC
    0029 32                RETI
                 ; FUNCTION external0 (END)
  • Yep. With only 2 data pointers, you can get into a lot of crazy situations saving and restoring both data pointers.
    The infineon 515 has 8 data pointers so you have 2 that are available for each register bank. That kinda makes things better.
    However, the best utilization of dual data pointers is for moving memory like you would do with memmove, memcpy, and so on.
    Jon
