Any of you have experience of maintaining several versions of the DK51 Dev. Kit in a computer? If it is possible, how can you do it without messing up with the uninstalling procedures? Thanks in advance, Jose
I have achieved this as follows; eg for v6.14 and 6.22: 1. Install v6.14 to C:\Program Files\Keil614 2. Install v6.22 to C:\Program Files\Keil622 This will give you v6.22 (ie, the last version installed) as your default version; To use v6.14, you have to manually run uv2.exe from the Keil614\uv2 folder (of course, you can set up a shortcut for this, and/or add an item to the Explorer Context menu - in the normal manner) All settings stored in the Registry (eg, the 'Tools' menu) will, of course, apply to both versions. Of course, you're on your own with a setup like this - it would be unreasonable to expect Keil to support it!
Take a look at the following knowledgebase article for another approach to this. http://www.keil.com/support/docs/2010.htm Jon
Mmm! I guess I used the wrong keywords searching the knowledgebase. Thanks! Jose
Take a look at the following knowledgebase article for another approach to this.<br> <br> <a href="">http://www.keil.com/support/docs/2010.htm">http://www.keil.com/support/docs/2010.htm</a><br> <br> Jon
sorry to be off-topic... but if you're the Andrew Neil I went to school with in Totnes, let me know! Deri
Well, I can't say that I've ever heard of anyone else called Deri Jones, so you're probably right!
