C182 error kicking my butt
Hopefully this makes sense. I've cut down the actual code to make this short.
I have a series of strings as shown:
char code Num1[] =  {"One  "};
char code Num2[] =  {"Two  "};
char code Num3[] =  {"Three"};
I then have an array of pointers that have all the address of the start of those strings:
code char code *CHNLTable[] = { Num1, Num2, Num3};
I then have a pointer in a function that I want to assign to an element in the array and I get a C182 "Pointer to different objects" warning.
void func(void){
  unsigned int *myptr;
   myptr = &CHNLTable;
   ...code that uses myptr
I don't understand the warning AND the code seems to work fine. Can someone explain to me the dumb thing I'm doing??
0
