Hi! I am using C51 V6.01, A51 V6.01 and BL51 V4.01 from command line. I have to execute an ISR on INT0 in 10us on 8051. So i am using Assembly for this ISR. However rest of the code is in C. As a first step i am trying to interface C & assembly by generating a 10Khz using Timer0 interrupt Here are the C and assembly progams i am trying to interface. c_func.c #include "Reg51.h" #define EN_ALL_INTS (IE|=0x80) #define EN_TIMER0_INT (IE|=0x02) #define ON_TIMER0 (TCON|=0x10) #define TH0_VAL 0xCE extern void T0_isr(void); void main(void) { TMOD=0x02;//8 bit autoreload for timer 0 TH0=TH0_VAL; EN_ALL_INTS; EN_TIMER0_INT; ON_TIMER0; while(1); } T0_isr.a51 NAME T0_isr PUBLIC T0_isr ORG 000BH T0_isr: CPL P1.0; RETI END 1. First i generate c_func.a51 from C51 2. I assemble both c_func.a51 and T0_isr.a51 using A51 3. I link both obj's from command line: bl51 c_func.obj,T0_isr.obj TO time.obj ramsize(128) CODE(30H) The problem is that the Hex file generated from time.obj using OH51 does not program the FLASH correctly. There is no code on 30H location. However there is code binary on 000BH. Hence the controller is not working. What should i do to correct this problem?
1. First i generate c_func.a51 from C51 2. I assemble both c_func.a51 and T0_isr.a51 using A51 Why not just compile c_func.c direct to .obj? 3. I link both obj's from command line: bl51 c_func.obj,T0_isr.obj TO time.obj ramsize(128) CODE(30H) What is the significance of 30H? Are you using an Evaluation version?
If i directly compile the C code then i get the following Warning message while linking: Code space memory overlap From :0000H T0 :000DH and the Hex file isnt generated in the next step. 30H is the Address from where the code space starts.The locations from 0 to 30H are reserved for interuppts
Yes i am using Eval version
The Eval version will never place code (apart from the interrupt vectors) below 0x4000. This was discussed recently on this forum, and is stated in the documentation: http://www.keil.com/demo/limits.htm
