Hello, I just want to code a binary data in C. I mean hera representation is "0x5F", the decimal representation is simply "156" but what is the decimal representation. I tried 0b010010101 but it doesn't work Many thanks Sébastien
C doesn't support binary numerical constants (see K&R). Perhaps a simple macro could help: #define BIN(b7,b6,b5,b4,b3,b2,b1,b0) ((b0)+((b1)<<1)+((b2)<<2)+((b3)<<3)+((b4)<<4)+((b5)<<5)+((b6)<<6)+((b7)<<7)) Then your constant would look like this: int i = BIN(1,0,0,1,0,1,0,1); Of course, you can extend the macro to suport a greater number of bits. Regards, Mike.
The ANSI 'C' language does have a binary data notation. I suppose you could do something with the preprocessor if it's really important to you; eg,
#define B_0000_0000 0x00 #define B_0000_0001 0x01 #define B_0000_0010 0x02 #define B_0000_0011 0x03 #define B_0000_0100 0x04 etc #define B_1111_1101 0xfd #define B_1111_1110 0xfe #define B_1111_1111 0xff
#define LongToBin(n) \ (\ ((n >> 21) & 0x80) | \ ((n >> 18) & 0x40) | \ ((n >> 15) & 0x20) | \ ((n >> 12) & 0x10) | \ ((n >> 9) & 0x08) | \ ((n >> 6) & 0x04) | \ ((n >> 3) & 0x02) | \ ((n ) & 0x01) \ ) #define Bin(n) LongToBin(0x##n##l)
A very elegant macro! Has its limitations, though (max. number of bits). But the idea is great.
Nice idea. By the way <pre> and </pre> need to be lower case.
When I said, "The ANSI 'C' language does have a binary data notation" what I meant was, of course, "The ANSI 'C' language does not have a binary data notation"
