Dear all, I have a small keyboard in my application and I poll all the keys periodically. I can read all the key values with 2 bytes. Next, I check the bits of these bytes for specific keys. In my program, I have function (check_button()) which gets the byte value and the bit index of the required key. It extracts the bit using '>>' and '<<', and interprets the value.
for (button_index=0; button_index<8; button_index++) check_button(button_port_1, button_index); : : : void check_button(unsigned char buttons, unsigned char button_index) { get the bit using << and >> process it }
for (button_index=0; button_index<8; button_index++) { button_port_1 >>= 1; (I need to get the carry bit) check_button(carry_bit_taken_above, button_index); }
Carry bit is accessible as 'CY' in C51; But beware - there is not necessarily any guarantee that the carry bit will be retained between 'C' statements. If you really need to be working at that level of machine-dependance, you probably need to do it in assembler. Note that C51 does provide a bit data type - could you use that, rather than rely specifically on the CPU's Carry Flag?
Andrew, Thanks for the reply. I know the bit data type. But, fastest way of accessing bits of a byte seems as using RRC and accessing carry flag. Am I wrong? Maybe I should change the question as follows: What is the fastest method to access any bit of a byte programmitically?
The question is really how to test a given bit in a byte. Here is code I often use.
typedef unsigned char BYTE; BYTE code BMaskC[8] = {0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80}; main() { BYTE Dummy; BYTE Button,Idx; if( Button & BMaskC[Idx] ) Dummy++; } ; FUNCTION main (BEGIN) 0000 E500 R MOV A,Idx 0002 900000 R MOV DPTR,#BMaskC 0005 93 MOVC A,@A+DPTR 0006 5500 R ANL A,Button 0008 6002 JZ ?C0002 000A 0500 R INC Dummy 000C ?C0002: 000C 22 RET
Jon, Thanks for the reply. I'll use this approach for bit access.
