hello: I compiled the following program with Keil6.14 compiler with 8th optimization, an error occured.the result is the "write" to the variable bit has net been sent ti the output port. Is this error caused by a bug of the compiler? No error occured when comping the program with 2rd optimzation.However because of the complication of the whole program and that many operations to port are needed,we can't use lower lever of optization.How can I do? Please ansrwer me quickly.Thank you. Email:zsz123@371.net Example: souce zs.c #pragma src #include <reg51.h> unsigned char bdata output; sbit prcck=output^3; void main (void) { unsigned char xdata *px; output=0x00; for(;;) { prcck=0; *px=output; prcck=1; *px=output; } } ; .\zs.SRC generated from: .\zs.c $NOMOD51 ?PR?main?ZS SEGMENT CODE ?DT?main?ZS SEGMENT DATA OVERLAYABLE ?BA?ZS SEGMENT DATA BITADDRESSABLE EXTRN CODE (?C_STARTUP) PUBLIC prcck PUBLIC output PUBLIC main RSEG ?DT?main?ZS ?main?BYTE: px?040: DS 2 RSEG ?BA?ZS output: DS 1 prcck EQU (output+0).3 ; #pragma src ; #include <reg51.h> ; ; unsigned char bdata output; ; sbit prcck=output^3; ; ; void main (void) RSEG ?PR?main?ZS main: ; SOURCE LINE # 7 ; { ; SOURCE LINE # 8 ; unsigned char xdata *px; ; output=0x00; ; SOURCE LINE # 10 CLR A MOV output,A ; for(;;) ; SOURCE LINE # 11 ?C0001: ; { ; SOURCE LINE # 12 ; prcck=0; ; SOURCE LINE # 13 CLR prcck ; *px=output; ; SOURCE LINE # 14 MOV DPL,px?040+01H MOV DPH,px?040 MOV A,output MOVX @DPTR,A ; prcck=1; ; SOURCE LINE # 15 SETB prcck ;*px=output; ; SOURCE LINE # 16 MOVX @DPTR,A ;this line is wrong ; } ; SOURCE LINE # 17 SJMP ?C0001 ; END OF main END
CHANGE:
volatile unsigned char bdata output;
Thank you !
