Compiler crashes with _push_/_pop_ instrinsics
When using the new instrinsic functions
_push_() and _pop_() with variables other than int, the compiler crashes.
Example:
#include <intrins.h>
void crash(void)
int *i;
// ... abritrary code
_push_(i);
i = _pop_();
Even and explicit type cast, such as
_push_((int)i);
i = (int*)_pop_();
wouldn't solve the problem.
BTW, the problem seems to be in the optimizer, because optimize levels below 2 (access optimization) work!
But as I wanted to utilize these instrinsics for producing very dense code, lowering the optimize level wouldn't be a proper work-around...
regards,
Ralf
