new c51 V620c BUG
When I use the new update C51 compiler C51 v620c to translate the following file with SRC directive, the result seems not correct,would keil surport please check it.
#pragma SRC
unsigned int ui_MixedParms(unsigned char ucA,bit btCheck, unsigned int uiB){
  if (btCheck)
    return(ucA + uiB);
  return(uiB - ucA);
the produced SRC fileis as follows:
; TST_C_Func2.SRC generated from: TST_C_Func2.c
NAME	TST_C_FUNC2
?PR?_ui_MixedParms?TST_C_FUNC2           SEGMENT CODE
?DT?_ui_MixedParms?TST_C_FUNC2           SEGMENT DATA OVERLAYABLE
?BI?_ui_MixedParms?TST_C_FUNC2           SEGMENT BIT OVERLAYABLE
	PUBLIC	?_ui_MixedParms?BIT
	PUBLIC	?_ui_MixedParms?BYTE
	PUBLIC	_ui_MixedParms
	RSEG  ?DT?_ui_MixedParms?TST_C_FUNC2
?_ui_MixedParms?BYTE:
        uiB?042:   DS   2
	RSEG  ?BI?_ui_MixedParms?TST_C_FUNC2
?_ui_MixedParms?BIT:
    btCheck?041:   DBIT   1
; unsigned int ui_MixedParms(unsigned char ucA,bit btCheck, unsigned int uiB){
	RSEG  ?PR?_ui_MixedParms?TST_C_FUNC2
_ui_MixedParms:
	USING	0
			; SOURCE LINE # 2
;---- Variable 'ucA?040' assigned to Register 'R5' ----
	MOV  	R5,AR7
;   if (btCheck)
			; SOURCE LINE # 4
	JNB  	btCheck?041,?C0001
;     return(ucA + uiB);
			; SOURCE LINE # 5
	MOV  	A,R5
	MOV  	R6,#00H
	ADD  	A,uiB?042+01H
	MOV  	R7,A
	MOV  	A,R6
	ADDC 	A,uiB?042
	MOV  	R6,A
	RET
?C0001:
;   return(uiB - ucA);
			; SOURCE LINE # 6
	CLR  	C
	MOV  	A,uiB?042+01H
	SUBB 	A,R5
	MOV  	R7,A
	MOV  	A,uiB?042
	SUBB 	A,#00H
	MOV  	R6,A
			; SOURCE LINE # 7
?C0002:
	RET
; END OF _ui_MixedParms
	END
the following line seems not correct,
        uiB?042:   DS   2
it should be :
        ucA?040:   DS   1
        uiB?042:   DS   2
Are these C51 V620c BUG?
