I have a problem with controller output. ( From controller's serial port via COM port i send data to my PC, and can recieve it on PC's Hyperterminal ). While testing the programm into debugger ( Keil C251 uVision2 ), i recieve the string, that i was sent from the programm. But from real controller i recieve that: if i use code
for ( i = 0; i < strlen (MyString); i ++) { TI = 0; SBUF = MyString[i]; while(!TI); }
for ( i = 0; i < 6; i ++) { TI = 0; SBUF = MyString[i]; while(!TI); }
What is the definition of MyString and your loop variable i ? What is output if you run the program in the simulator ? Looks like a missing zero to terminate the string. HHK
Yes - check for that NULL terminator!
Thanks for answer MyString & i are "unsigned char". Gennady
Thanks to everybody a lot. It works perfect. My problem realy was a NULL terminator. Thanks Gennady.
The variable MyString is probably NOT the same name as the string variable that you want to output. Is MyString a pointer??? Jon
Now that you've fixed the missing NULL terminator, why not use
for ( i = 0; MyString[i]; i ++ ) etc
This is the exact output you will get if MyString is located in external memory at address xx4C and the memory is not connected.
