I have to mimic a project produced by a consultant no longer in favor, and in order to match the product as it is (comparing .hex files) I must do things the following way: .. in a DOS batchfile .. with the same modules linked in the same sequence .. with the modules currently in libraries in libraries. I have all source, just no makefiles. My problem is that when I put the '&' at the end of the first part of my BL51 line the linker stops using the .bat file and display >> on the console. Any advice as to how to handle this using the given criteria will be greatly appreciated. thanx in advance Erik
What OS are you using? Remember that '&' (and "&&") is a reserved character in Win-NT (and maybe its successors?). You can "escape" it with '^' (caret). See "What's New or Different from MS-DOS" in the Win-NT Help (on the 'Start' menu). Have you tried the syntax:
BL51 @commandfile
Thanx Andy, the BL51 @doit.cmd did the trick.
