dscope and serial simulation
I was trying to simulate the serial ports.
I have implemented a circular buffer, i read that the serial window allows you to input data by using the keyboard.
Now do i need to use the assign commands etc to make sure it goes to the interrupt routine?
Where is this information set?
I'm reading in SBUF but the interrupt didn't appear to get called
thanks
David
