How can I access the XDATA memory block after 64Kbypes in Dallas DS5240 environment? I now use 24bit contiguous mode to compile the program and I want to access a memory address in xdata 0x200000.... *((unsigned char xdata *)0x200000) = 0x0b; C Compiler error occur. Then I try... DPX = 0x20; *((unsigned char xdata *)0x0000) = 0x0b; There is no error in C compiler. However, I find the object code is 0034 90000000 MOV DPTR,#00H ^^-- force DPX = 0x00 0038 740b MOV A,#0bH 003A F0 MOVX @DPTR,A How can I do?
The 'far' memory type implements access to the full 24-bit XDATA address range.
I have checked the "Options for target"/"'far' memory type support". How can I point to 24-bit XDATA address range? I have tried ... *((unsigned char xdata far *)0x200000) = 0x01; ---- not compiled *((unsigned char far *)0x200000) = 0x01; ---- I have checked the list file... This statement is compiled as follwing and it does not sound work ; SOURCE LINE # 91 000A 7800 MOV R0,#00H 000C 7601 MOV @R0,#01H Do I miss any steps or keywords? Thank you!
