Guys, I'm facing a bit strange problem. I'm not able to download the entire code (Hex file size : 48 K) using the uVision2 mon251 dll though I'm able to do the same for code of smaller sizes. After downloading around 55% of 48k it sarts cribbing: "Command WriteBlock timed out". The FF segment is 64K in size so I really don't think it could be a memory shoratge problem. What could be possible is that Monitor code or data segments might be overwritten. So I compared the MAP files of both my application program and the Monitor 251. The MAP file of MON251 says START STOP SEGMENT NAME ========================================000000H 000007H "REG BANK 0" 010000H 01001FH ?FD?MON251_DATA FF0000H FF0104H INITSEG FF0105H FF01A8H INSTALLCODE FF01A9H FF07E7H ?PR?MON251 FFFFF8H FFFFF9H ?CO?INSTALL?1 The MAP file of the application says FF0000H FF0226H ?CO?asm?0 FF0000H FF0002H ?CO?START251?4 FF000BH FF000DH ?PR?IV?1 FF0227H FF0C1DH ?PR? XYZ Apparently there is some overlap in the code segment area (I checked out the data segment areas for both. They seemed to be fine). I tried relocating my "asm" segment to some other address using ORG instruction but it didn't do the required thing. What could be the problem in this entire episode. Do I need to relocate some part of the code segment of my application to somewhere else. If so how do we do that ?? thanx, vipin
If you are using the eval board from Keil, the board uses addresses from FF:E000 to FF:FFFF for hardware and the monitor EPROM. This memory needs to be reserved in the linker with the reserve memory directive (see the L251 linker manual). The class directive can be used to specify what addresses each segment can use, so you may need to add this to the linker options as well. This is also detailed in the L251 manual.
