Problem with C51 v5.5 and Atmel Dual Pointers
Hi, all.
I seem to have a problem with C51
(DOS) v5.50 and the Atmel AT89S53.
The program is all C (no assembler) and
accesses different parts of XDATA memory
from both the normal main program and
also from an interrupt function. It
appears that main's xdata addresses are
corrupted. The problem goes away if the
pragma is removed.
The v5.5 release notes say that the
MODA2 pragma is only for the AT89S8252,
but as I understand it all the Atmel
AT89 cores implement the dual pointers
in the same way.
The problem also goes away if I don't
use strcpy, which may point to a library
issue.
Has anyone else seen this problem?
Would a subtle error in the header file
for the processor have any bearing on
the problem?
Your thoughts would be appreciated.
Richard
