Where is possible really get support from KEIL ?
Click on the 'Support' link above, then choose the 'E-Mail Support' link under 'Getting Support' Simple, eh?
Which email you can advise me ? support@keil.com support.us@keil.com support.intl@keil.com or "web-based technical support form " ? I tried all last month. Also, I send email copies directly to Reinhard Keil and Rudolf Baumgartner via old email's which I receive in previous cases last year. I send 4 email's last month and have no answer's. Sorry, 1 answer I have from email robot on support@keil.com that my "inquiry" resended to support.intl@keil.com :) What happened ? All KEIL support peoples now have holidays or bussines trip :) ? If you from KEIL, you can answer to my email in "E-mail" field of this message, now hidden from spamers (Thanks to Jon Ward ).
Why not ask your questions here to start with? - Mark
Sergey, Last time I sent a message to Keil support in September 2000. I got the answer in January 2001, when, naturally, nobody needed it any longer. Be patient. Or rather send your troubles to this forum. Bud' prosche - i ludi k tebe potyanutsya. Michael.
Am I the only guy who gets support from Keil? Every time I ask a question from support, I usually get an answer within 1-2 days.
Maybe you are! I'm afraid that I have also found that answers to questions to the "official" Keil E-mail support addresses can take a very long time, or sometimes appear to get lost all together.
>Why not ask your questions here to start with? Don't understand how you can help me ... Ok. You can try reproduce this bug in C251 v2.14n, XSMALL memory model.
// ---- Beginning of ERR_PTR.C ---- typedef unsigned char UCHAR; typedef void * PTVOID; typedef struct { // Some structure with size <= 4 bytes UCHAR uc0; UCHAR uc1; UCHAR uc2; UCHAR uc3; } STR_A, *PTSTR_A; typedef struct { // Some structure with size > 4 bytes UCHAR uc0; UCHAR uc1; UCHAR uc2; UCHAR uc3; UCHAR uc4[10]; } STR_B, *PTSTR_B; // 'volatile' just to prevent optimizing volatile PTSTR_A pa1,pa2; volatile PTSTR_B pb1,pb2; PTSTR_A f_a( PTVOID p) { return( (PTSTR_A) p ); } PTSTR_B f_b( PTVOID p) { return( (PTSTR_B) p ); } void main(void) { *pa1 = *pa2; //OK_1, (copy via ?C?BMOVEPP8) *pb1 = *pb2; //OK_2, (copy via ?C?BMOVEPP8) *pa1 = *f_a( (PTVOID) pa2 ); // BUG_1 *pb1 = *f_b( (PTVOID) pb2 ); // BUG_2 } // ---- End of ERR_PTR.C ----
; FUNCTION f_a?_ (BEGIN) ; SOURCE LINE # 22 ;---- Variable 'p' assigned to Register 'DR0' ---- ; SOURCE LINE # 24 000000 7F10 MOV DR4,DR0 ; SOURCE LINE # 25 000002 22 RET ; FUNCTION f_a?_ (END) ; FUNCTION f_b?_ (BEGIN) ; SOURCE LINE # 27 ;---- Variable 'p' assigned to Register 'DR0' ---- ; SOURCE LINE # 29 000000 7F10 MOV DR4,DR0 ; SOURCE LINE # 30 000002 22 RET ; FUNCTION f_b?_ (END) ; FUNCTION main (BEGIN) ; SOURCE LINE # 32 ; *pa1 = *pa2; //OK_1, (copy via ?C?BMOVEPP8) ; SOURCE LINE # 34 000000 7E1F0000 R MOV DR4,pa2 000004 7E0F0000 R MOV DR0,pa1 000008 7404 MOV A,#04H ; A=R11 00000A 120000 E LCALL ?C?BMOVEPP8 ; *pb1 = *pb2; //OK_2, (copy via ?C?BMOVEPP8) ; SOURCE LINE # 35 00000D 7E1F0000 R MOV DR4,pb2 000011 7E0F0000 R MOV DR0,pb1 000015 740E MOV A,#0EH ; A=R11 000017 120000 E LCALL ?C?BMOVEPP8 ; *pa1 = *f_a( (PTVOID) pa2 ); // BUG_1 ; SOURCE LINE # 36 00001A 7E0F0000 R MOV DR0,pa2 00001E 120000 R LCALL f_a?_ 000021 7E0F0000 R MOV DR0,pa1 000025 79300002 MOV @DR0+2,WR6 000029 1B0A20 MOV @DR0,WR4 ; *pb1 = *f_b( (PTVOID) pb2 ); // BUG_2 ; SOURCE LINE # 37 00002C 7E3F0000 R MOV DR12,pb1 000030 7E0F0000 R MOV DR0,pb2 000034 120000 R LCALL f_b?_ ; SOURCE LINE # 38 000037 22 RET ; FUNCTION main (END) C251 COMPILER V2.14n, ERR_PTR
*pa1 = (STR_A)f_a( (PTVOID) pa2 );
*ptr_To_Structure_X = *function_Returning_Ptr_To_Structure_X();
tmp_ptr_To_Structure_X = function_Returning_Ptr_To_Structure_X(); *ptr_To_Structure_X = *tmp_ptr_To_Structure_X;
I believe you have a C language mistake, not a compiler bug.
// ---- Beginning of ERR_PTR.C ---- typedef unsigned char UCHAR; typedef void * PTVOID; typedef struct { // Some structure with size <= 4 bytes UCHAR uc0; UCHAR uc1; UCHAR uc2; UCHAR uc3; } STR_A, *PTSTR_A; typedef struct { // Some structure with size > 4 bytes UCHAR uc0; UCHAR uc1; UCHAR uc2; UCHAR uc3; UCHAR uc4[10]; } STR_B, *PTSTR_B; // 'volatile' just to prevent optimizing volatile PTSTR_A pa1,pa2; volatile PTSTR_B pb1,pb2; PTSTR_A f_a( PTVOID p) { return( (PTSTR_A) p ); } PTSTR_B f_b( PTVOID p) { return( (PTSTR_B) p ); } void main(void) { *pa1 = *pa2; //OK_1, (copy via ?C?BMOVEPP8) *pb1 = *pb2; //OK_2, (copy via ?C?BMOVEPP8) *pa1 = *f_a( (PTVOID) pa2 ); // BUG_1: you've stripped the volatile qulifier. *pb1 = *f_b( (PTVOID) pb2 ); // BUG_2: you've stripped the volatile qulifier. }
typedef struct { // Some structure with size <= 4 bytes volatile UCHAR uc0; volatile UCHAR uc1; volatile UCHAR uc2; volatile UCHAR uc3; } STR_A, *PTSTR_A; typedef struct { // Some structure with size > 4 bytes volatile UCHAR uc0; volatile UCHAR uc1; volatile UCHAR uc2; volatile UCHAR uc3; volatile UCHAR uc4[10]; } STR_B, *PTSTR_B; // Pointers point to a struct with all elements volatile. We don't need volatile // on our struct pointers now. PTSTR_A pa1,pa2; PTSTR_B pb1,pb2; // and then replace f_a and f_b with proper casts. Simple is better. pb1 = (PTSTR_B *) pba1; pb2 = (PTSTR_B *) pba2;
>I believe you have a C language mistake, not a compiler bug In real program: - there are no 'volatile' attributes and called functions are 'extern'. - 'Typedefs' widely used in real program by compatibility and easy porting reason's. However, 1) Keyword 'volatile' was added just in example only to prevent compiler optimization and in fact have no meaning for discussed problem. 2) All used in example 'Typedefs' also have no meaning for discussed problem, the same result if using
STR_A * f_a( void * p) {...}
PTSTR_A f_a( PTVOID p) {...}
// This line produce crazy code or no code at all ... *ptr_To_Structure_X = *function_Returning_Ptr_To_Structure_X();
// This line produce true code - just save function result to temporary pointer tmp_ptr_To_Structure_X = function_Returning_Ptr_To_Structure_X(); // This line work good because produce call to library function *ptr_To_Structure_X = *tmp_ptr_To_Structure_X;
Sergey, I looked through our support log and only found 1 e-mail that we just received from you on February 15, 2001. I didn't see that any other e-mails came to support@keil.com or support.us@keil.com from you since the beginning of the year. Maybe you used a different e-mail address? You may also want to check your sent items folder to be sure you actually sent the e-mail to us. Since you are located outside of North/South America, we forwarded your request on to Germany for technical support. Most of the office there has been out last week at the Embedded Systems Show, so turn-around time for questions was probably slow because of that. Nonetheless, I have been able to duplicate the problem you are speaking of and have forwarded it to engineering. We should hear something in a few days on that. Jon
If you supply me with your email, I can resend all my original letters to: <support@keil.com> <support.us@keil.com> <support.intl@keil.com> <Rudolf Baumgartner> <Reinhard Keil> More punctually, one answer I receive from email-robot on 'support@keil.com' that my inquire was recended to support.intl@keil.com. Thats all.
