This is probably a C question!
Hello again,
I convert an Ascii file (about 10kB size) to HEX using the BIN2HEX and declaring a file start segment of 4800 (...absolute address 0x48000). When starting debugging in simulation mode using uVision2, I load it to my target (load MYFILE.HEX).
Using a far pointer I'm trying to read all the memory locations from 0x48000 to 0x4A400 but I get nil on the serial window.
I check the memory using the command "Display" and MYFILE is loaded in address 0x40000 (not 0x48000) and even when I redirect the pointer's offset to 0x40000 I still get nothing.
unsigned int i;
	char far *pointer;
	pointer=0x48000;
	for (i=0x0; i<0x2400; i++)
		putchar(*(pointer+i));
I use the small memory model with Near memory set to 32kB RAM. My ROM is 0x0-0x3FFFF.
And in case that helps...
FDATA (0x40000-0x4FFFF), FDATA0 (0x40000-0x4FFFF),
HDATA (0x40000-0x4FFFF), HDATA0 (0x40000-0x4FFFF),
XDATA (0x40000-0x4FFFF), XDATA0 (0x40000-0x4FFFF))
DPPUSE (0=NDATA(0x40000 - 0x47FFF), 2=NCONST(0x0 - 0x3FFF))
CINITTAB (0x10000-0x3FFFF)
Can you please help me with that? How can I read the loaded file?
Regards
George
  • You might try using a huge pointer. Look at an assembly listing to see if the address being computed is using pag or seg address. It could be that adding i to a page address doesn't handle crossing page address boundaries.
