Dear sir, The sample code available on your site is not yet finished for the MCB167-NET kit. When can we expect a new release for this item ? Is there someone else who's using the same evaluation board and does already have functional "demo"-software ? Best Regards.
What examples do you need? If you need TCP/IP examples, CMX (http://www.cmx.com) and U S Software (http://www.ussw.com) both offer stacks for this board. Keil Support
At BlueWind we have been developing TCP/IP-based applications based on USSW libraries running on C16x, with hardware solution very similar to the one used MCB167NET. We also developed a driver for CS8900 to be used in the USSW library, on a board based on C161. Unfortunatly, any piece of software implementing a TCP/IP stack that derives from a commercial library (like USSW and others) would be covered by a copyright (and a *very expensive* one) and no free implementation of a TCP/IP stack exist (as far as my knowledge extends) that could fit on a C16x (not a serious one). We have a license from USSW that allows us to prepare any kind of demo application based on MCB167NET board, and I'm inviting you readers of this forum to suggest us the kind of demo that could be more appreciated, but in any case the TCP/IP part of this would be only an executable or library, not source code! bye- Stefano ---------------------------------------- BlueWind Electronic Design I-31033 Castelfranco Veneto (TREVISO) Via Steffani 7/B ---------------------------------------- VOICE +39 0 423 723431 FAX +39 0 423 744738 MOBILE +39 335 6565749 mailto:stefano@bluewind.it http://www.bluewind.it ----------------------------------------
Paul, I forgot to mention: please have a look at http://www.embeddedethernet.com/ for example code (only *partial* implementations of a TCP/IP stack, but perheaps this is ok for a simple domotica system not having to connect to the outside world). The code and examples are written for other CPUs but the ethernet device is CS8900, so a porting to MCB167 should be very easy. Please let me know is something interesting arises from your work! bye- Stefano stefano@bluewind.it
