Problem: Unable to execute the program with banking. The operating system i am using is windows 95, my target hardware has the following settings a)common area - 1400 to 7fff (VNM) b)banked area - 8000 to fdff (vnm) c)no of banks - 15 (all are vnm) d)monitor program located at 0000-13ff in the common area (reading using psen signal) In the program I have used the following settings in the mon_bank.a51 $NOCOND DEBUGPUBLICS ?B_NBANKS EQU 16 ?B_MODE EQU 0 ?B_BANKSTART EQU 08000H ?B_BANKEND EQU 0FdFFH ?B_COMMON EQU 0FFH ?B_XRAM EQU 0FFH ?B_MON_DATA_BANK EQU 11 IF ?B_MODE = 0; ?B_PORT EQU P1 ?B_FIRSTBIT EQU 0 ENDIF; And rest of the settings are default. Whenever I am loading the program to target board (we are using keil monitor 51 in debug settings)using uv2 and watch port p1, it always shows bank11 (?B_MON_DATA_BANK setting) (if i change the above setting to bank07 P1 shows always bank7) When I execute the program in the stepinto mode, the program shows as if the program is swithcing the banks, but when I watch the port p1, P1 shows always bank 11 The above program works properly in debug simulator mode and I am able to see the port P1 changing as per the banks selected I have created the mon51.hex file using the following command: install 0 14 0 BANK i.e., 256 bytes for monitor program is from 1400 to 14ff, our program starts from 3800h (i.e., code start is from 3800h which is set in l51_locate and xdata is set 1500H) I am setting the l51_bank.a51 with the following settings $NOMOD51 $NOCOND ;************************ Configuration Section ******************************* ?B_NBANKS EQU 16 ?B_MODE EQU 0 ?B_RTX EQU 0 ?B_VAR_BANKING EQU 0 IF ?B_VAR_BANKING <> 0 ?B_COMMON_XRAM EQU 0 ?B_INTR_ACCESS EQU 0 ENDIF IF ?B_MODE = 0 P1 DATA 90H ?B_PORT EQU P1 ?B_FIRSTBIT EQU 3 ENDIF And rest of the settings are default. When I run this program using simulator and when I watch ports under the menu Peripherals it shows 4 ports of 8 bit width and when I run the same program using Monitor51 mode and when I watch ports under the menu Peripherals it shows 8 ports of 8 bit width. Aswath
