My problem: My program is able to send messages but not to save the incoming messages. The following program shoud be able to save the incoming telegrams and then send the new information out. Is somebody able to help me. Maybe its an initialization problem. Here are the source code without the headers:
#pragma small #include <regc515c.h> #include <c515can.h> #include<absacc.h> void lesen (void); void Empfang (void); void iniint(void); void inican(void); void ini_ACC1(void); unsigned char empf[8]; void iniint(void) { TMOD=0x11; /* 16 bit timer*/ TR0=0; /*timer0 off*/ TH0=0xBB; /*timer 0 load with 10 ms */ TL0=0x00; TF0=0; /*timerflag clear*/ TR0=1; /*timer0 on*/ EAL=1; /*enable interrupt*/ ET0=1; /*interrupt for Timer0 on*/ } void inican(void) { SYSCON = 0x20; // XMAP0 und XMAP1, on extern CR = 0xfc; GMS0 = 0xFF; // mask off GMS1 = 0xFF; UGML0 = 0xFF; UGML1 = 0xFF; LGML0 = 0xFF; LGML1 = 0xFF; UMLM0 = 0xFF; UMLM1 = 0xFF; LMLM0 = 0xFF; LMLM1 = 0xFF; CR = 0x41; // start initialization -> INIT=1, CCE=1 BTR0 = 0xC0; BTR1 = 0x6B; // from ApNote 0820 SR = 0xE7; // TXOK and RXOK clear CR = 0x00; // CCE=0 -> Baudrate off MCR0_1=0x55; // messages off MCR0_2=0x55; MCR0_3=0x55; MCR0_4=0x55; MCR0_5=0x55; MCR0_6=0x55; MCR0_7=0x55; MCR0_8=0x55; MCR0_9=0x55; MCR0_A=0x55; MCR0_B=0x55; MCR0_C=0x55; MCR0_D=0x55; MCR0_E=0x55; MCR0_F=0x55; SYSCON = 0x21; // XMAP0, extern off } //************************************************************************************** void ini_ACC1(void) { SYSCON = 0x20; MCR1_5 = 0xFB; /*CPUUPD=1*/ UAR0_5 = 0x3A; UAR1_5 = 0x00; /*identifier 0x1D0*/ MCFG_5 =0x88; /*data length, transmission */ DB0_5 = 0x00; DB1_5 = 0x00; DB2_5 = 0x00; DB3_5 = 0x00; DB4_5 = 0x00; DB5_5 = 0x00; DB6_5 = 0x00; DB7_5 = 0x00; MCR0_5 = 0xA5; /*MSGVAL=1, TXIE=1, RXIE=0???, INPND=0;*/ MCR1_5 = 0x55; /*RMTPNP=0, TXRQ=0, CPUUPD=0, NEWDAT=0*/ SYSCON = 0x21; } //************************************************************************************** void Empfang (void) // telegram incoming message { SYSCON = 0x20; MCR1_6 = 0xFB; /*MSGLST/CPUUPD=1*/ UAR0_6 = 0xa4; UAR1_6 = 0x60; /*identifier 0x523h*/ MCFG_6 = 0x80; /*datalength incoming message*/ MCR0_6 = 0xA9; /*MSGVAL=1, TXIE=1, RXIE=1,INPND=0;*/ MCR1_6 = 0x55; /*RMTPNP=0, TXRQ=0, CPUUPD=0, NEWDAT=0*/ SYSCON = 0x21; } //******************************read void lesen (void) //read incoming message { SYSCON = 0x21; empf[0] = DB0_6; empf[1] = DB1_6; empf[2] = DB2_6; empf[3] = DB3_6; empf[4] = DB4_6; empf[5] = DB5_6; empf[6] = DB6_6; empf[7] = DB7_6; SYSCON = 0x20; } //**************************zyklisch()******************************** void zyklisch (void) interrupt 1 { static unsigned char x; TR0=0; /*Timer0 off*/ TH0=0xBB; /*Timer0 = 10ms */ TL0=0x00; TF0=0; /*Timerflag 0 clear*/ TR0=1; /*Timer0 start*/ x++; if(x==2) { x=0; lesen(); SYSCON = 0x20; DB0_5 = empf[0]; DB1_5 = empf[1]; DB2_5 = empf[2]; DB3_5 = empf[3]; DB4_5 = empf[4]; DB5_5 = empf[5]; DB6_5 = empf[6]; DB7_5 = empf[7]; MCR1_5 = 0xEF; /*Send ACC1 to CAN-BUS*/ SYSCON = 0x21; } } //****************************************** void main (void) { Empfang (); iniint(); inican(); ini_ACC1(); while(1); }
I set up a CAN interface on the 515 about a year ago using DAVE. I only had one end to bring up as I was using the CANPort from emicros as a poor mans CANalyzer. I wish I still had the code for you to see but I have since switched to the C164. My best advice is to get the interface running with DAVE, it seems almost foolproof. My C164 CAN came up very easily using DAVE as well. Good Luck Eric
Thanks for your interest. I will try to get Dave. I have already contact infineon and I hope to get it in the next days. Sincerly, Zurek Sebastian
