Monitor166
Two HEX files are loaded into some memory locations (using the "load <myfile.HEX>" command)
Immediately after start debugging on the target board using monitor166, I can browse the loaded files using the "d 0xAddr1, 0xAddr2" command.
If I start running the debug session, after stopping on a breakpoint I'm not able to see the loaded HEX files anymore. The memory now seems to be empty (actually all memory locations are filled with the value A6!).
I also get the same results immediately after starting the debug session, when the "Go till main()" box is selected.
Is that a normal behavior of the monitor166 or it's possibly something wrong with the external memory that I just have interfaced to the C167CR?
Thank you
