Hi folks, I have tried the following source code and it seemed not behaving what I was expected
#define Const1 (10) #define Const2 (Const1/4096) #define Base (2850) unsigned int g_wData; float g_fA = Base; float g_fB = Base; u8 IsChanged(void) { g_fA = Base + (Const2 *g_wData); /*if the two value are the same,just return 0*/ /*else return 1 and assign the new value to...*/ if(g_fA == g_fB ) { return (0); } g_fB = g_fA ; return (1); }
The values you are using in the macro definitions are integers and thus, when used, Const2 yields a subexpression value of zero and g_fA will always equal g_fB. Change:
#define Const1 (10)
#define Const1 (10.0)
#define Const2 (Const1/4096.0)
Open the option of the target and go to the "c51" page, try to select a bigger number than 3 in the "bits to round for float" column. ps. The Const1 and Const2 should be defined with float numeric. A floating-point compare is not a good idea for a mcu program. Try to use the "long int" type instead of it.
