Hello Everyone,
I am just starting with a new board, a landboard with a nxp LPC1768.
I do not understand why i go in debug mode the starting point of my PC is 0x1fff0080
I use the startup given in keil 4 lite. This address is not random. In fact when I'm also trying with different example,
written in c, the starting point is the main of the c file, but if i hit the reset button, again the starting point is that address.
this is the disassembly but i cannot find nothing on the startup that redirect to that address.
0x1FFF007A 0000 MOVS r0,r0 0x1FFF007C 0000 MOVS r0,r0 0x1FFF007E 0000 MOVS r0,r0 0x1FFF0080 F8DF4018 LDR.W r4,[pc,#24] ; @0x1FFF009C 0x1FFF0084 F8DF5010 LDR.W r5,[pc,#16] ; @0x1FFF0098 0x1FFF0088 6826 LDR r6,[r4,#0x00] 0x1FFF008A EA050606 AND r6,r5,r6 0x1FFF008E 6026 STR r6,[r4,#0x00] 0x1FFF0090 F8DFF000 LDR.W pc,[pc,#0] ; @0x1FFF0094 0x1FFF0094 0201 LSLS r1,r0,#8 0x1FFF0096 1FFF SUBS r7,r7,#7 0x1FFF0098 BFFF ITTTT 0x1FFF009A FFFFC3C0 DCD 0xC3C0FFFF 0x1FFF009E 400F ANDS r7,r7,r1 0x1FFF00A0 0000 MOVS r0,r0 0x1FFF00A2 0000 MOVS r0,r0
When i debug in simulation mode instead, the starting point is the reset Handles...
PRESERVE8 THUMB ; Vector Table Mapped to Address 0 at Reset AREA RESET, DATA, READONLY EXPORT __Vectors __Vectors DCD __initial_sp ; Top of Stack DCD Reset_Handler ; Reset Handler ..... IF :LNOT::DEF:NO_CRP AREA |.ARM.__at_0x02FC|, CODE, READONLY CRP_Key DCD 0xFFFFFFFF ENDIF AREA |.text|, CODE, READONLY ; Reset Handler Reset_Handler PROC my code ENDP
Can you please help me to understand what i'm wrong?
Thank you
Sorry you did not see a response on this. The Reset_Handler is indeed where execution begins, and can be thought of as the low-level entry point. This will ultimately call __main, the C library init code, which eventually calls main(), the standard start of the code from a C perspective.The debugger allows you to skip through this code (you may not wish to consider what is happening therein), with the 'run to main()' check box in the debugger configuration.
Check what boot options your device has, via external strapping or whatever, 0x1FFFxxxx is suggestive of the device's ROM as opposed to user FLASH at 0x08000000
Check what memory is mapped/shadowed at zero, and if that looks like the vector table for your code or not.
