I am trying to install latest version keil 5.25 on windows 7 occurs followimg problem:
1) when i open keil ide then showing this message keil ide stop working
2) in task manager that error show as a SECSplashWnd.
for above problem I am trying following method:
1) check windows compatibility.
2) check resolution.
3) reinstall keil mdk 5.25.
4) clear registry before install.
please advise me i am too much stuck on this problem...
Try to run UVision with argument "-nosplash".
From command line : "uv4.exe -nosplash"
Please try MDK 5.26 pre-release. You find the download link on this page: http://www2.keil.com/mdk5/
Did you install an older version of uVision on this PC before?
Are you using a 7-day MDK-pro license or a FlexNet license?
