arm_sqrt_f32() is missing in CMSIS CM7 math library
It appears the CMSIS math library for Cortex-M7 is missing arm_sqrt_f32().  I ran objdump on the library and arm_sqrt_f32() is missing.  The library contains arm_sqrt_q15(), arm_sqrt_q31() but does not have arm_sqrt_f32().
CMSIS_5/CMSIS/Lib/GCC/libarm_cortexM7lfdp_math.a
arm_sqrt_f32()
This impacts things beyond arm_sqrt_f32() because other functions require it in particular the FFT arm_rfft_fast_f32().
In archive CMSIS_5-develop\CMSIS\Lib\GCC\libarm_cortexM7lfdp_math.a:
arm_const_structs.o:     file format elf32-littlearm
architecture: arm, flags 0x00000011:
HAS_RELOC, HAS_SYMS
start address 0x00000000
arm_common_tables.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_q31_to_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_q31_to_q7.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_q31_to_float.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_q15_to_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_q15_to_q7.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_q15_to_float.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_q7_to_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_q7_to_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_q7_to_float.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_float_to_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_float_to_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_float_to_q7.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fill_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fill_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fill_q7.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fill_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_copy_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_copy_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_copy_q7.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_copy_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_var_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_var_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_var_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_std_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_std_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_std_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_rms_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_rms_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_rms_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_power_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_power_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_power_q7.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_power_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_min_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_min_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_min_q7.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_min_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mean_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mean_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mean_q7.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mean_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_max_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_max_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_max_q7.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_max_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_sin_cos_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_sin_cos_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_pid_reset_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_pid_reset_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_pid_reset_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_pid_init_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_pid_init_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_pid_init_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cfft_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cfft_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_rfft_fast_init_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_rfft_fast_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_bitreversal2.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cfft_radix8_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cfft_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cfft_radix2_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cfft_radix2_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cfft_radix2_init_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cfft_radix2_init_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cfft_radix2_init_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cfft_radix2_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_bitreversal.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_rfft_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_rfft_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_rfft_init_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_rfft_init_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_rfft_init_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_rfft_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_dct4_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_dct4_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_dct4_init_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_dct4_init_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_dct4_init_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_dct4_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cfft_radix4_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cfft_radix4_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cfft_radix4_init_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cfft_radix4_init_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cfft_radix4_init_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cfft_radix4_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mat_inverse_f64.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mat_cmplx_mult_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mat_cmplx_mult_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mat_cmplx_mult_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mat_trans_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mat_trans_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mat_trans_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mat_sub_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mat_sub_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mat_sub_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mat_scale_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mat_scale_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mat_scale_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mat_mult_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mat_mult_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mat_mult_fast_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mat_mult_fast_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mat_mult_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mat_inverse_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mat_init_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mat_init_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mat_init_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mat_add_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mat_add_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mat_add_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_biquad_cascade_stereo_df2t_init_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_biquad_cascade_stereo_df2t_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_biquad_cascade_df2t_init_f64.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_biquad_cascade_df2t_f64.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_biquad_cascade_df2t_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_conv_partial_fast_opt_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_conv_fast_opt_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_correlate_fast_opt_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_correlate_opt_q7.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_conv_partial_opt_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_conv_partial_opt_q7.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_conv_opt_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_conv_opt_q7.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_correlate_opt_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_lms_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_lms_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_lms_norm_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_lms_norm_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_lms_norm_init_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_lms_norm_init_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_lms_norm_init_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_lms_norm_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_lms_init_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_lms_init_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_lms_init_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_lms_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_iir_lattice_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_iir_lattice_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_iir_lattice_init_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_iir_lattice_init_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_iir_lattice_init_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_iir_lattice_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_sparse_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_sparse_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_sparse_q7.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_sparse_init_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_sparse_init_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_sparse_init_q7.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_sparse_init_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_sparse_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_q7.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_lattice_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_lattice_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_lattice_init_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_lattice_init_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_lattice_init_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_lattice_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_interpolate_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_interpolate_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_interpolate_init_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_interpolate_init_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_interpolate_init_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_interpolate_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_init_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_init_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_init_q7.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_init_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_fast_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_fast_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_decimate_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_decimate_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_decimate_init_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_decimate_init_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_decimate_init_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_decimate_fast_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_decimate_fast_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_fir_decimate_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_correlate_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_correlate_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_correlate_q7.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_correlate_fast_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_correlate_fast_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_correlate_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_conv_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_conv_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_conv_q7.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_conv_partial_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_conv_partial_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_conv_partial_q7.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_conv_partial_fast_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_conv_partial_fast_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_conv_partial_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_conv_fast_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_conv_fast_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_conv_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_biquad_cascade_df2t_init_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_biquad_cascade_df1_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_biquad_cascade_df1_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_biquad_cascade_df1_init_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_biquad_cascade_df1_init_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_biquad_cascade_df1_init_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_biquad_cascade_df1_fast_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_biquad_cascade_df1_fast_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_biquad_cascade_df1_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_biquad_cascade_df1_32x64_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_biquad_cascade_df1_32x64_init_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cmplx_mult_real_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cmplx_mult_real_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cmplx_mult_real_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cmplx_mult_cmplx_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cmplx_mult_cmplx_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cmplx_mult_cmplx_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cmplx_mag_squared_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cmplx_mag_squared_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cmplx_mag_squared_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cmplx_mag_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cmplx_mag_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cmplx_mag_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cmplx_dot_prod_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cmplx_dot_prod_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cmplx_dot_prod_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cmplx_conj_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cmplx_conj_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cmplx_conj_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_sqrt_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_sqrt_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_sin_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_sin_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_sin_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cos_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cos_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_cos_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_sub_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_sub_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_sub_q7.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_sub_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_shift_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_shift_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_shift_q7.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_scale_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_scale_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_scale_q7.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_scale_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_offset_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_offset_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_offset_q7.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_offset_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_negate_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_negate_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_negate_q7.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_negate_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mult_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mult_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mult_q7.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_mult_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_dot_prod_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_dot_prod_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_dot_prod_q7.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_dot_prod_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_add_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_add_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_add_q7.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_add_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_abs_q31.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_abs_q15.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_abs_q7.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
arm_abs_f32.o:     file format elf32-littlearm
HAS_RELOC, HAS_SYMS
