Issues while running benchmarks for Arm RAN Acceleration Library version 23.04
I have installed ARM RAL version,23.04 on my Linux machine and successfully built static libraries for Release  mode with Arm GNU Toolchain 12.2.Rel1 (arm-gnu-toolchain-12.2.rel1-x86_64-aarch64-none-linux-gnu.tar.xz) for targets NEON and SVE.I enabled build options ,-DBUILD_TESTING=On` and `-DBUILD_EXAMPLES=On. Python version installed on my machine is 3.8.10.and Linux, Perf tool version is perf version 5.15.87,required for running benchmarks.
After build,I installed ARMRAL libraries for 2 targets in 2 different installation folders.
Afterwords,I tried running benchmarks with command, make bench for 2 targets separately one by one but for each one I am getting errors like following for all benchmarks.....
If I direct o/p to file,JSON objects printed are like below  indicating that benchmarks not ran at all.:--
{"name": "demodulation_qam256_8", "error": true, "ts": 304990550, "dur": 192588}
{"name": "demodulation_qam256_31", "error": true, "ts": 305183343, "dur": 192250}
{"name": "demodulation_qam256_32", "error": true, "ts": 305375812, "dur": 194988}
Since I am evaluating ARMRAL for my work and new to ARMRAL, could you kindly look into the error and help me to identify root cause(eg whether I m missing something/making some error) and fix the error soon?
It would help a lot.
Regards,
Pankaj K
Failed to run command: ['/home/sitteam/PankajK/arm-ran-acceleration-library-23.04/bench/default_runner.py', '/home/sitteam/PankajK/arm_lib_2304_build_NEON_static_rel/bench_demodulation', '{"name": "demodulation_qam16_276", "args": "1 276", "reps": 300000}']
Traceback (most recent call last):
File "/home/sitteam/PankajK/arm-ran-acceleration-library-23.04/bench/default_runner.py", line 65, in <module>
main()
File "/home/sitteam/PankajK/arm-ran-acceleration-library-23.04/bench/default_runner.py", line 61, in main
run(args.exe_path, case_json)
File "/home/sitteam/PankajK/arm-ran-acceleration-library-23.04/bench/default_runner.py", line 37, in run
all_cycles = [run_perf(args) / float(reps) for _ in range(10)]
File "/home/sitteam/PankajK/arm-ran-acceleration-library-23.04/bench/default_runner.py", line 37, in <listcomp>
File "/home/sitteam/PankajK/arm-ran-acceleration-library-23.04/bench/default_runner.py", line 20, in run_perf
result = exec_and_check_cmd(cmd)
File "/home/sitteam/PankajK/arm-ran-acceleration-library-23.04/bench/default_runner.py", line 14, in exec_and_check_cmd
result.check_returncode()
File "/usr/lib/python3.8/subprocess.py", line 448, in check_returncode
raise CalledProcessError(self.returncode, self.args, self.stdout,
subprocess.CalledProcessError: Command '['perf', 'stat', '-x', ' ', '-e', 'cycles:u', '/home/sitteam/PankajK/arm_lib_2304_build_NEON_static_rel/bench_demodulation', '1', '276', '300000']' returned non-zero exit status 255.
