Hi HPC Community,
I’ve recently developed an early automation to testbed for SIMD optimized algorithms utilization in Java. The codebase utilizes the Java Vector API to explore the performance gains and challenges of SIMD operations. My goal is to investigate how Java’s evolving vectorization support can be leveraged for high-performance computing, specifically focusing on all personal, server-grade and commercial machines.
What I've Built:
The automation is designed to run on OpenJDK 17 or later (with preview features enabled). It leverages Maven for dependency management and build automation, and Make for task orchestration, including running benchmarks.
I’m using JMH (Java Microbenchmark Harness) as the primary framework to build, run, and analyze nano/micro/milli/macro benchmarks. JMH’s flexibility allows me to target various aspects of performance for Java and other JVM languages (maybe in the future), ensuring a comprehensive evaluation of SIMD operations using the Java Vector API.
In the GitHub repository, you will find the source code of the testbed and the early algorithms I’ve used for the benchmarks, allowing you to replicate the tests or build upon them. I’ve also included some early results from running the benchmarks on my personal machines (more to be added), alongside a very brief analysis of these findings.
Key Areas of Interest:
Call for Feedback and Collaboration:
I’m eager to hear your feedback on the performance gains and limitations you've encountered with SIMD and the Java Vector API. Suggestions for additional algorithms, code optimization, or any other improvements are more than welcome.
If anyone in the community has access to more specialized hardware (ARM-based or otherwise) and would be willing to help run additional benchmarks, I’d love to collaborate. Optimizing this across a broader range of machines would offer deeper insights into how this approach could scale for real-world HPC applications.
You can find the code repository here: GitHub - java-vector-api-playground.
Feel free to dive in, run your own tests, and share your thoughts. If you'd like to get in touch directly, my email is contact@....
Looking forward to your thoughts, advice, and collaboration opportunities!
Best regards,
IP
