I have just downloaded and installed latest APL (24.04) on my windows on arm device. I am currently just making some small tests, but cmake fails to find apl. To reproduce, here is my CMakeLists file:
cmake_minimum_required(VERSION 3.18) project(DUMMYAPL) set(BLA_VENDOR Arm) find_package(BLAS) add_executable(main main.cpp) if (BLAS_FOUND) target_include_directories(main PRVATE ${BLAS_INCLUDE_LIBRARIES}) target_link_libraries(main PRVATE ${BLAS_LIBRARIES}) else() message(FATAL_ERROR “APL NOT FOUND”) endif()
and this is my main.cpp file:
#include <iostream>#include “armpl.h”
int main() {std::cout << “Success” << std::endl;return 0;
It fails with this error: – Could NOT find BLAS (missing: BLAS_LIBRARIES)When I try a similar approach on my windows intel device( I just replace armpl.h with mkl.h and the BLA_VENDOR with Intel10_64lp), it works. Does someone know why this ight be happening ?
Hi Alin Pahontu,Unfortunately find_package(BLAS) for Arm PL isn't supported on Windows yet. CMake itself will need to be updated.
find_package(BLAS)
In the meantime, you could try to add the following to your CMakeLists.txt file to let CMake know about Arm PL on Windows:
cmake_minimum_required(VERSION 3.19) project(DUMMYAPL) set(ARMPL_ROOT "C:/Program Files/Arm Performance Libraries/armpl_24.04") add_library(armpl SHARED IMPORTED GLOBAL) set_property(TARGET armpl PROPERTY IMPORTED_LOCATION ${ARMPL_ROOT}/lib/armpl_lp64.dll.lib) set_property(TARGET armpl PROPERTY IMPORTED_IMPLIB ${ARMPL_ROOT}/lib/armpl_lp64.lib) set_property(TARGET armpl PROPERTY INTERFACE_INCLUDE_DIRECTORIES ${ARMPL_ROOT}/include) add_executable(main main.cpp) target_link_libraries(main PRIVATE armpl)
Kevin
Thank you for the fast reply, Kevin. I'll try it this way instead
