Hello, I have a question regarding this sample code. I created a new source containing this code in both examples_lp64 and examples_ilp64 folders and added the new file to the both makefiles to compile it. For the 32-bit version it works well and outputs the correct result ( Value of r: 0.123400 ) but for the 64-bit one, it results in an error (NMAKE : fatal error U1077: 'test.exe' : return code '0xc0000005' ). Am I doing something wrong, or what can the problem be ?
#include <stdlib.h> #include <stdio.h> float x[4] = { 1, 2, 3, 4 }; float y[4] = { .1, .01, .001, .0001 }; int four = 4; int one = 1; extern float sdot_(); int main() { int i; double r = sdot_(&four, x, &one, y, &one); printf("Value of r: %f\n", r); return 0; }
Looks like you're passing the integer arguments to `sdot_` as pointers to 32-bit integers. When linking against the 64-bit library, you'll need to ensure that you pass in 64-bit integers.
You can either correct this by instead passing in pointers to `int64_t` types in your 64-bit example:
int64_t four = 4; int64_t one = 1;
Or for both 32-bit & 64-bit examples, you can include armpl.h and use the `armpl_int_t` typedef to get the correct integer type that matches the interface:
#include <armpl.h> armpl_int_t four = 4; armpl_int_t one = 1;
For more information on the 64-bit integer interface, please see: https://developer.arm.com/documentation/101004/2404/General-information/Arm-Performance-Libraries-variants-using-64-bit-integer-arguments.
Hope this helps!
Aymen
