Hi all,
we are facing below issue, while launching ARM forge MAP tool, could you please help us t resolve the issue
/opt/arm/forge/22.1.2/bin~$ ./map
/opt/arm/forge/22
.1.2
/bin~$ ./map
puTTy X11 proxy: Unsupported authorisation protocol.
Unable to connect to display.
Thanks & regards
Manjunath
Hi Manjunath jayram, thanks for asking a question in our support forums. To help you find an answer, I have moved your question to the HPC forum. Many thanks.
Hi Manjunath,
Sorry to move you again but it would be great if you would be able to send an email to the Forge support email at: support-hpc-sw@arm.com with your issue.
From the error it looks like it might be an issue with how Putty/X11 forwarding is set up, we generally recommend running Forge using remote connect as explained in the User-guide here https://developer.arm.com/documentation/101136/22-1-3/Arm-Forge/Connecting-to-a-remote-system/Remote-connections-dialog?lang=en but if you send us an email we will try and help diagnose the problem.
Thank you Joshua Cottingham for your help here.
