I am suspecting an inefficient memory usage in my application. I would like to understand where the memory is allocated/used in my application. Is it possible to use AR forge products to backtrack memory usage to individual variables/objects in my C++ code base.
There are a couple ways to do this in our tools. In the debugger DDT you can use the 'Tools | Overall Memory Stats' dialog or 'Tools | Current Memory Usage Dialog'. Also, in our source code profiler MAP you can use memory profiling to get insights on this. If you are interested in a demo of how to do this, please contact me at Beau.Paisley@arm.com and I would be glad to provide that.
