SVE Instruction to get index of first true element
in SVE, I can use `svcmpeq_u64` to compare two svuint64_t vectors. The result is a `svbool_t` predicate. Now, I can use `svlastb_` functions to extract the element itself. However, as I am implementing a linear search using SVE, I am not interested in the element itself (I know what I am searching for), but the _index_ of the first true match in the svbool_t returned by the comparison function.
I was not able to find any function that gives me the index of the first true element in a svbool_t. In x86 SSE, for example, I can create a movemask and count trailing zeros to index my comparison results. In NEON, I can do the same by using an emulated movemask function, but I don't know how to do it natively in NEON. How would I do this on SVE?
Thank you so much for your help.
Best,
Maxbit
  • Hi Maxbit,
    You are correct that there is no way to directly extract the index of the first predicated element in SVE, however there are a couple of different approaches you can take to achieve this.
    In particular you can use the `svindex` intrinsic to generate a vector of 0,1,... and then use `svlastb` on that instead, which will give you the index you are after.
    It is also worth pointing out that your question says the first matching element, but `svlastb` will return the last matching element instead. If you can guarantee that there is only a single matching element then this is fine, but if not then you may need to first adjust the predicate such that the last element is the one you are after. You can do this with either `svbrka_b_z` or `svpfirst_b` to ensure that the first matching element of your input predicate is the last one of the resulting predicate that you pass to `svlastb`.
    Putting that all together and you might end up with something like this:
    #include <arm_sve.h>
    #include <stdio.h>
    uint64_t find_first_index(svuint64_t x, svuint64_t y) {
      svbool_t ptrue = svptrue_b8();
      svbool_t p = svcmpeq_u64(ptrue, x, y);
      return svlastb_u64(svbrka_b_z(p, p), svindex_u64(0, 1));
    int main() {
      uint64_t data1[4] = { 0, 1, 2, 3 }; // assume vl=256, adjust as needed
      uint64_t data2[4] = { 3, 2, 2, 3 };
      svuint64_t x = svld1(ptrue, data1);
      svuint64_t y = svld1(ptrue, data2);
      printf("%lu\n", find_first_index(x, y));
    You will need to be careful that you do not try to use this in a situation where none of the elements match, but you can avoid this by simply checking `svptest_any` and continuing your search if none are found.
    Hope that helps,
    George
  • Dear George,
    thank you so much. I was not aware of the index instructions, that is indeed a very clever way to handle this problem. It works great for my use case. Thank you so, so much!
    I have two follow-up questions on this.
    a) Do you believe there is any performance difference between svbrka_b_z and svpfirst_b? Probably it is very minor anyway, but I was just wondering whether I should benchmark this thoroughly.
    b) Of course, I need to provide a NEON fallback implementation for finding the first match. Currently, my NEON code looks like this:
    /* The following two functions implement the index of first match calculation */
    // adapted from https://github.com/DLTcollab/sse2neon/blob/master/sse2neon.h
    HEDLEY_ALWAYS_INLINE static uint32_t movemask_sse2neon(uint8x16_t input) {
    uint16x8_t high_bits = vreinterpretq_u16_u8(vshrq_n_u8(input, 7));
    uint32x4_t paired16 = vreinterpretq_u32_u16(vsraq_n_u16(high_bits, high_bits, 7));
    uint64x2_t paired32 = vreinterpretq_u64_u32(vsraq_n_u32(paired16, paired16, 14));
    uint8x16_t paired64 = vreinterpretq_u8_u64(vsraq_n_u64(paired32, paired32, 28));
    return vgetq_lane_u8(paired64, 0) | ((int)vgetq_lane_u8(paired64, 8) << 8);
    HEDLEY_ALWAYS_INLINE static uint32_t non_sve_vector_first_index(vector_type vector) {
    uint32_t mask = movemask_sse2neon(to_uint8_vec(vector));
    // __builtin_ctz does not work with all zero mask
    if (mask == 0) {
      return INVALID_IDX;
    return __builtin_ctz(mask) / static_cast<uint32_t>(sizeof(KeyT));
    /* The next function implements the any_found check */
    HEDLEY_ALWAYS_INLINE static bool non_sve_vector_any_nonzero(vector_type input) {
    // Idea: 1. Reinterpret vector_type as uint64x2_t (if necessary)
    // 2. Our 128-bit register now contains two 64-bit uints. Only if both of them are zero, there is no zero bit
    uint64x2_t reinterpreted;
    if constexpr (std::is_same_v<_vector_type, uint64x2_t>) {
      reinterpreted = input;
    } else {
      if constexpr (std::is_same_v<_vector_type, uint8x16_t>) {
        reinterpreted = vreinterpretq_u64_u8(input);
      } else if constexpr (std::is_same_v<_vector_type, uint16x8_t>) {
        reinterpreted = vreinterpretq_u64_u16(input);
      } else if constexpr (std::is_same_v<_vector_type, uint32x4_t>) {
        reinterpreted = vreinterpretq_u64_u32(input);
      } else {
        FAIL("Unsupported vector type in conversion");
    return vgetq_lane_u64(reinterpreted, 0) | vgetq_lane_u64(reinterpreted, 1);
    As you can see, it is quite complicated and has overhead, especially because I did not know how to handle the index calculation efficiently in NEON. On x86 SEE, again, I can use the TZCNT and movemask intrinsics, but I could not find equivalents for NEON. Do you also have a clever idea on how to make this NEON code more efficient? It should basically achieve the same result as the SVE code we discussed above, i.e., we have a vector that is result of a comparison, e.g., by `vceqq_u64`, and then we implement a test function to check whether there was any match and a function that gets the first index of the match.
    Thank you so, so much for your help. I am quite new to ARM SIMD programming and just getting the hang of the differences compared to SSE/AVX.
    Best,
    Maxbit
  • Hi Maxbit,
    (a) For comparing different choices of instruction sequences you can refer to the software optimisation guides available on developer.arm.com, for example for Neoverse V1: https://developer.arm.com/documentation/pjdoc466751330-9685/latest/ . On Neoverse V1 at least it appears that BRKA and PFIRST instructions have identical latency and throughput, so which one you use probably doesn't matter, but I would suggest checking the guide for the exact core you are interested in.
    (b) For the Neon equivalent as you point out there is no nice sequence here. The fastest sequence will probably depend both on how frequently the INVALID_IDX path is taken compared to an actual index being found, as well as the particular core you are interested in, so I'd recomment benchmarking a couple of different alternatives yourself to see which one works better for your use case.
    For the code itself: comparisons in Neon like `vceqq` will set matching elements to all-ones, so you can take advantage of that in a couple of ways:
    • You can use the UMAXV instruction and then compare this against zero to see if any elements match.
    • You can use the comparison result and AND that against a hard-coded vector of {1,2,...}, then use UMINV, take one away from that to find the minimum matching index (you need to avoid zero here since the non-matching cases will already be zero). Unlike SVE you don't need an INDEX instruction here, you can just hard-code it since the vector length is known at compile time.
    • You can alternatively use BSL instead of AND to select the passing elements into a {0,1,...} vector and the others to -1, to avoid needing to subtract one at the end.
    Since Neon vectors are only a pair of uint64_t elements wide, you might actually find it quicker to extract out the pair of elements and just call e.g. __builtin_ctz twice. In general the scalar instructions have lower overheads for such short sequences.
    I appreciate that's a bit of a vague answer. Let me know if you run into any other problems and I can try and throw a more complete example together.
  • Dear George,
    Thank you so much again for your help and please excuse my late answer. I am currently implementing several variants that you suggested in order to benchmark them. I have one question on the UMINV approach, maybe I am overseeing something.
    The comparison result vector will be a vector of either all 1-bit or all 0-bit entries. If I element-wise AND this vector with our {1,2,3,..} index vector, the smallest non-zero number that remains is the index we are looking for. However, the AND will turn indices where there was no match into 0, and as 0 will be smaller than any of our other indices, UMINV will always return 0. Or am I getting something wrong here? We would need an instruction for the smallest non-zero value, wouldn't we?
    Thank you for clearing that up.
    Best,
    Maxbit
  • Hi Maxbit,
    You are correct, the UMINV approach doesn't work as I imagined. You could try instead ANDing it with the bitwise negation of the index (which is a large unsigned number) and use UMAXV instead. Something like:
    #include <arm_neon.h>
    #include <stdio.h>
    int main() {
      uint32x4_t x = {0, 0, ~0U, ~0U};
      uint32x4_t y = {~0U, ~1U, ~2U, ~3U};
      uint32_t idx = ~vmaxvq_u32(vandq_u32(x, y));
      printf("idx = %u\n", idx);
    Thanks,
    George
