Recently for some reason, I've been having issues with DDT and Express Launch. It used to work but then...something changed and now it does. For example, if I do this:
ddt -connect mpirun -np 96 ./GEOSgcm.x
on more than one node, the resulting DDT launch stalls out. I see it launch on the first node (45 of the 96 processes), but then things halt and it's stuck there.
But if I do:
ddt -connect ./GEOSgcm.x
and then set things up manually it works.
The one difference is that the Express Launch chose "Intel MPI (MPMD)" and I manually chose "Intel MPI". (I believe there are three Intel MPI possibilities?)
So I'm wondering, is there an environment variable or something I can use to let Arm Forge know that "if you detect Intel MPI, please choose 'Intel MPI' and not 'Intel MPI (MPMD)'"?
