Set Mali GPU operating frequency
Hello, I am currently using Pixel6 and Pixel8 with GPU
Mali-G78 MP20, Mali-G715 MP7 respectively.
For previous devices, setting GPU frequency manually was possible setting
"userspace" as governor and using "set_freq" to choose among available frequencies but it seems outdated.
Is there any way I can manually set Mali GPU frequency?
If this isn't a right place to ask this type of question, where should I ask it?
Thank you
  • There is no standard way to do this; the power management is outside of the GPU hardware from Arm and it depends on the integration provided by the device manufacturer. In this case you'd need to ask Google.
    HTH,
    Pete
