latest Unity 2021.3.0
GLES3.2
Graphics Analyzer Version: 5.13.0.6d7b7c21
GPU processing budget approach to game development - Graphics, Gaming, and VR blog - Arm Community blogs - Arm Community
After reading the above article, I plan to follow the methods mentioned in the article to create a function that can automatically perform statistics through a script. However, I encountered the following problems.
I encountered two problems.
1.I want to capture frames of a Unity game using cmd-line instead of GUI. I used the following command: ".\aga-headless.bat -d f031bf6f --process com.unity.srpbatcherbench -t 10 --trace-file-output D:\trace.mgd --frames-with-fragment-count 10". Then an error occurred.
February 27, 2024 9:29:45 PM com.arm.mgd.core.util.CoreLogging info
Information: Using Mali-T880 r2p0 (Mali-T600_r13p0-00rel0) for shader compilation.
Maximum ESSL version: 320.
Supported extensions: GL_ARM_shader_framebuffer_fetch GL_ARM_shader_framebuffer_fetch_depth_stencil GL_EXT_shader_pixel_local_storage GL_OES_EGL_image_external GL_OES_gpu_shader5 GL_OES_texture_buffer GL_OES_texture_cube_map_array GL_ANDROID_extension_pack_es31a GL_EXT_color_buffer_half_float GL_EXT_color_buffer_float GL_KHR_blend_equation_advanced GL_OES_sample_variables GL_OES_shader_image_atomic GL_OES_shader_multisample_interpolation GL_OES_texture_storage_multisample_2d_array GL_EXT_geometry_shader GL_EXT_gpu_shader5 GL_EXT_primitive_bounding_box GL_EXT_shader_io_blocks GL_EXT_tessellation_shader GL_EXT_texture_buffer GL_EXT_texture_cube_map_array.
Information: Checking for headless mode authorization...
Information: ADB location retrieved from saved preferences: C:\Users\lizhirui01\AppData\Local\Android\Sdk\platform-tools\adb.exe
Information: Checking for install directory at: D:\Program Files\Arm\Arm Performance Studio 2024.0\graphics_analyzer\gui\..
Information: Device manager initialized.
February 27, 2024 9:30:01 PM com.arm.mgd.core.util.CoreLogging info
Information: Installing tracing components to device - please wait...
Information: Installation/removal progress: Installing interceptors
February 27, 2024 9:30:04 PM com.arm.mgd.core.util.CoreLogging info
Information: Installation/removal progress: Installing GA daemon
February 27, 2024 9:30:05 PM com.arm.mgd.core.util.CoreLogging info
Information: Installation/removal progress: Launching GA daemon
Information: Tracing components installed onto device
February 27, 2024 9:30:10 PM com.arm.mgd.core.util.CoreLogging info
Information: Failure occurred. Removing tracing components from device - please wait...
Information: Installation/removal progress: Stopping GA daemon
February 27, 2024 9:30:11 PM com.arm.mgd.core.util.CoreLogging info
Information: Installation/removal progress: Removing GA daemon
Information: Installation/removal progress: Removing layers
February 27, 2024 9:30:12 PM com.arm.mgd.core.util.CoreLogging info
Information: Removal of tracing components complete
February 27, 2024 9:30:12 PM com.arm.mgd.core.util.CoreLogging log
Warning: Connection to ADB failed.
Connection refused when connecting to OnePlus KB2000.
No input received when trying to read the trace version. Is the interceptor daemon running?
2.After I execute the command "adb shell settings put global gpu_debug_app com.unity.srpbatcherbench", I directly open the game on the phone, and the game will crash directly.
Is there a solution to these two problems? Or is there a new approach to perform a time-consuming statistics on game scenes for VS and PS?
Thanks in advance
Graphics Analyzer is deprecated, so for debugging we would recommend using RenderDoc.Our new Frame Advisor tool can provide performance feedback, but it's not yet doing shader analysis - this will come later in the year.
HTH, Pete
