Can anyone throw some light on ACE-Lite Slaves
a ) Do they have inbuilt coherent caches? Can they be snooped?
b) What type of ACE-Lite transactions are directed to them and what are the responses?
Uma
Hi Uma,
My blog gives an overview of hardware coherency fundamentals: Extended System Coherency - Part 1 - Cache Coherency Fundamentals
It's useful at this point to clarify the difference between masters and slaves. A master will generate requests, e.g. a CPU or DMA. A Slave will respond to requests, e.g. a memory controller or memory mapped peripheral. ACE-Lite is a subset of ACE (and indeed a super-set of AXI). ACE interfaces are for fully coherent agents, and ACE-Lite is one-way coherent or "IO-Coherent" which means it can snoop the ACE processors, but the ACE processors cannot snoop the ACE-Lite masters.
An example of an ACE-Lite master is the Mali-T880 GPU which does also include caches. However as it is only IO coherent these internal GPU caches will need to be managed by software, usually by cleaning at the end of every frame.
If we're now looking at ACE-Lite slaves this could cover two types of IP:
For full details of the specification please look at the AMBA specification: http://www.arm.com/products/system-ip/amba-specifications.php
Thanks!
Neil.
