I recently purchased the ARM Embedded Linux course and I can't seem to get past lab 1 after running the command "$ bitbake rpi-basic-image". I need help, I am using ubuntu 18.04.5 VM for the course. Here is the log file output after the build failed:
DEBUG: Executing shell function do_compileNOTE: make -j 1: && /bin/mkdir -p doc && { PATH='/home/klem/raspberryPi3/rpi-build/tmp-glibc/work/x86_64-linux/automake-native/1.15-r0/build/t/wrap:'$PATH && export PATH; } && /usr/bin/perl ../automake-1.15/doc/help2man --output=doc/automake-1.15.1 automake-1.15help2man: can't get `--help' info from automake-1.15Try `--no-discard-stderr' if option outputs to stderrMakefile:3687: recipe for target 'doc/automake-1.15.1' failedmake: *** [doc/automake-1.15.1] Error 255WARNING: exit code 1 from a shell command.ERROR: oe_runmake failedERROR: Function failed: do_compile (log file is located at /home/klem/raspberryPi3/rpi-build/tmp-glibc/work/x86_64-linux/automake-native/1.15-r0/temp/log.do_compile.15219)
