I am following the ARM Embedded linux course material and in the lab 1 there is an introduction on how to build an image for a raspberry pi 3. I followed the steps in the course and after modifying the files of bblayers.conf and local.conf, I run the command of bitbake rpi-basic-image which gives me an error of do_compile: oe_runmake failed. How to solve this? I have attached the log file, If I need to add more information do let me know.
I am a beginner in this field so any help would be appreciated.
Log:
DEBUG: Executing shell function do_compileNOTE: make -j 1: && /bin/mkdir -p doc && { PATH='/home/cb/raspberryPi3/rpi-build/tmp-glibc/work/x86_64-linux/automake-native/1.15-r0/build/t/wrap:'$PATH && export PATH; } && /usr/bin/perl ../automake-1.15/doc/help2man --output=doc/automake-1.15.1 automake-1.15help2man: can't get `--help' info from automake-1.15Try `--no-discard-stderr' if option outputs to stderrMakefile:3687: recipe for target 'doc/automake-1.15.1' failedmake: *** [doc/automake-1.15.1] Error 255WARNING: exit code 1 from a shell command.ERROR: oe_runmake failedERROR: Function failed: do_compile (log file is located at /home/cb/raspberryPi3/rpi-build/tmp-glibc/work/x86_64-linux/automake-native/1.15-r0/temp/log.do_compile.1066)
CRB said:the (sic) ARM Embedded linux course
Which one?
can't your course tutors help with this?
CRB said:log file is located at /home/cb/raspberryPi3/rpi-build/tmp-glibc/work/x86_64-linux/automake-native/1.15-r0/temp/log.do_compile.1066
have you looked at that log file to see what it tells you?
where you able to solve this issue? I am having exactly the issue in the lab 1. I need help! here's the log file output:
DEBUG: Executing shell function do_compileNOTE: make -j 1: && /bin/mkdir -p doc && { PATH='/home/klem/raspberryPi3/rpi-build/tmp-glibc/work/x86_64-linux/automake-native/1.15-r0/build/t/wrap:'$PATH && export PATH; } && /usr/bin/perl ../automake-1.15/doc/help2man --output=doc/automake-1.15.1 automake-1.15help2man: can't get `--help' info from automake-1.15Try `--no-discard-stderr' if option outputs to stderrMakefile:3687: recipe for target 'doc/automake-1.15.1' failedmake: *** [doc/automake-1.15.1] Error 255WARNING: exit code 1 from a shell command.ERROR: oe_runmake failedERROR: Function failed: do_compile (log file is located at /home/klem/raspberryPi3/rpi-build/tmp-glibc/work/x86_64-linux/automake-native/1.15-r0/temp/log.do_compile.15219)
Hey, Following the same course. Having the same issue. Can someone please help?
I'll try to help2man. I hope it's useful to future desperados, hang in there!
There's a good chance you're doing "Embedded Linux Online Course" and you're getting this error in your lab 1. I can tell you that I spent hours/days trying to get around this error and I still couldn't fully execute bitbake command and build distro image. That's why I decided to try another branch of poky, meta-openembedded and meta-raspberrypi. One that's used in the lab is "krogoth", but that branch lacks a lot of important patches. The one that worked for me was "sumo", it has 2.5.3 distro version and it just works. So, go change the branch. Now how do you do that? Easy, delete all content of ~/raspberryPi3/sources and run these commands, if you want sumo branch:
git clone -b sumo git://git.yoctoproject.org/pokygit clone -b sumo git://git.openembedded.org/meta-openembeddedgit clone -b sumo git://git.yoctoproject.org/meta-raspberrypi
You should follow the remaining steps of the lab and you'll need to include following line in your "rpi-build/conf/bblayers.conf":
${BSPDIR}/sources/meta-openembedded/meta-python \
I hope this'll help someone.
