Site
Search
User
Site
Search
User
Support forums
LDR Instruction
Jump...
Cancel
State
Not Answered
Replies
Subscribers
141 subscribers
Views
Users
0 members are here
Architecture
Instruction Set
Thumb
Thumb2
Options
More actions
Cancel
Related
LDR Instruction
subin t
over 12 years ago
Note: This was originally posted on 5th November 2008 at
http://forums.arm.com
Hi all,
I am new to the thumb-2 instruction set. In one of my sample code
I noticed a instruction
LDR r0, =0x12345678;
This instruction actually load the r0 with value (0x12345678).
But I didn't find such an instruction anywhere in the thumb-2 instruction set.
I am wondering anyone is aware of such instruction and from where i can find
more details about the thumb-2 instruction set.
0
Jacob Bramley
over 12 years ago
That is a pseudo-instruction, and actually expands to multiple real instructions. If assemble the code then view the disassembly of the result, you'll see something like this:
0x1000: LDR r0, [pc,#8]
0x1008: .DCD 0x12345678
This is called a "PC relative load". The ".DCD" directive simply allows you to insert arbitrary data into the instruction stream. Of course, you'd never execute that data, so your code will have to branch around it.
Using assembler, you can also specify exactly where the literal pools should be using another assembler directive. There are various reasons why you might want to do that.
So, to answer your question, the instruction you show isn't part of the Thumb-2 (or ARM) instruction set, but is expanded into real instructions by the assembler. You'll need to look at the documentation for the specific assembler in order to find out more, but the format you're using works in every assembler I've used.
Cancel
Vote up
0
Vote down
Accept answer
Cancel
0
Peter Harris
over 12 years ago
It is also worth noting that "LDR rd, =X" may not assemble to an "LDR" at all.
If X is a small enough literal value to fit into the MOV instruction encoding you might see a single MOV instruction.
Cancel
Vote up
0
Vote down
Accept answer
Cancel
