AXI transaction failure
Hello everyone,
I'm pretty new to axi and i still try to figure things out. I'm using Zybo device and created a custom ip with a master and a slave interfaces. I have create design as you can see in the below. Write transaction is work however, read transaction does not.
However i have test it by using AXI Verification IP and following this tutorial . It worked as you can see below. After the design below, i put interconnect between VIP and myIP, it also worked. I believe problem is the PS. I really appreciate if you help me.
Thank you very much.
0
