Cannot install Android on Juno board...
 Hi.
So I have tried to install Android on the juno board following the instructions from here: https://community.arm.com/dev-platforms/b/documents/posts/using-linaros-deliverables-on-juno
However I cannot get it to boot up into to the OS..
Can someone help...
Attached is the log file.
Thanks,
ThomLOG.TXT
  • Apparently I did not attach the correct log file. This is where it hangs:
    [ 13.247916] init: write_file: Unable to open '/sys/class/android_usb/android0/functions': No such y
    [ 13.258284] init: write_file: Unable to open '/sys/class/android_usb/android0/enable': No such fily
    [ 13.269338] init: write_file: Unable to open '/sys/class/android_usb/android0/enable': No such fily
    [ 13.279473] init: write_file: Unable to open '/sys/class/android_usb/android0/idVendor': No such fy
    [ 13.289785] init: write_file: Unable to open '/sys/class/android_usb/android0/idProduct': No such y
    [ 13.300178] init: write_file: Unable to open '/sys/class/android_usb/android0/functions': No such y
    [ 13.310562] init: write_file: Unable to open '/sys/class/android_usb/android0/enable': No such fily
    shell@juno:/ $ [ 13.389643] type=1400 audit(3047867008.604:21): avc: denied { read } for pid=176 co1
    [ 13.407774] type=1400 audit(3047867008.604:22): avc: denied { open } for pid=176 comm="gatord" pat1
    [ 13.428483] type=1400 audit(3047867008.604:23): avc: denied { getattr } for pid=176 comm="gatord" 1
    [ 13.450683] type=1400 audit(3047867008.604:24): avc: denied { write } for pid=176 comm="gatord-mai1
    [ 13.469085] type=1400 audit(3047867008.604:25): avc: denied { add_name } for pid=176 comm="gatord-1
    [ 13.485486] audit: audit_lost=1 audit_rate_limit=20 audit_backlog_limit=64
    [ 13.485489] audit: rate limit exceeded
    [ 13.496884] type=1400 audit(3047867008.604:26): avc: denied { create } for pid=176 comm="gatord-ma1
    [ 13.513975] type=1400 audit(3047867008.604:27): avc: denied { mounton } for pid=176 comm="gatord-m1
    [ 13.533306] type=1400 audit(3047867008.604:28): avc: denied { read } for pid=176 comm="gatord-main1
    [ 13.553087] type=1400 audit(3047867008.604:29): avc: denied { read } for pid=176 comm="gatord-main1
    [ 13.571905] type=1400 audit(3047867008.604:30): avc: denied { open } for pid=176 comm="gatord-main1
    [ 13.592605] type=1400 audit(3047867008.604:31): avc: denied { read } for pid=176 comm="gatord-main1
    [ 13.612151] type=1400 audit(3047867008.604:32): avc: denied { open } for pid=176 comm="gatord-main1
    [ 13.636065] type=1400 audit(3047867008.688:33): avc: denied { execute } for pid=176 comm="gatord-m1
    [ 13.655561] type=1400 audit(3047867008.700:34): avc: denied { create } for pid=176 comm="gatord-ma1
    [ 13.671537] type=1400 audit(3047867008.700:35): avc: denied { net_raw } for pid=176 comm="gatord-m1
    [ 13.688814] type=1400 audit(3047867008.700:36): avc: denied { setopt } for pid=176 comm="gatord-ma1
    [ 13.704769] type=1400 audit(3047867008.700:37): avc: denied { bind } for pid=176 comm="gatord-main1
    [ 13.720552] type=1400 audit(3047867008.700:38): avc: denied { name_bind } for pid=176 comm="gatord1
    [ 13.737985] type=1400 audit(3047867008.700:39): avc: denied { node_bind } for pid=176 comm="gatord1
    [ 13.755402] type=1400 audit(3047867008.700:40): avc: denied { listen } for pid=176 comm="gatord-ma1
    [ 13.772332] type=1400 audit(3047867008.700:41): avc: denied { create } for pid=176 comm="gatord-ma1
    [ 13.788276] type=1400 audit(3047867008.700:42): avc: denied { setopt } for pid=176 comm="gatord-ma1
    [ 14.470631] init: Starting service 'bootanim'...
    [ 14.504562] type=1400 audit(3047867009.716:46): avc: denied { getattr } for pid=329 comm="bootanim0
    [ 15.637849] type=1400 audit(3047867010.852:47): avc: denied { write } for pid=177 comm="zygote64" 0
    [ 15.658591] type=1400 audit(3047867010.868:48): avc: denied { write } for pid=178 comm="zygote" na0
    [ 20.381586] capability: warning: `main' uses 32-bit capabilities (legacy support in use)
    [ 26.928121] healthd: battery l=100 v=0 t=42.4 h=2 st=2 chg=a
    [ 28.933200] smsc911x 18000000.ethernet eth0: SMSC911x/921x identified at 0xffffff80093e0000, IRQ: 4
    [ 28.942433] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [ 32.169338] init: Service 'bootanim' (pid 329) exited with status 0
  • Hi Thom,
    You've actually successfully booted there, it's just that Android is spamming your console with text.
    See this line: `shell@juno:/ $ ' <-- That's your shell.
    If you hit the Enter key a few times you'll be able to see a bit easier and can start using the shell as normal :)
    Hope that helps,
    Ash.
