Juno Board - 32-bit Linux Kernel
is there any 32-bit Linux Kernel for the Juno board?  I have an application where I can't use 64-bit Kernel.
Thank you.
  • Hello Ash,
    Unfortunately that would not work in my case: I have a hardware debugger which requires another expensive license to debug 64-bit Kernels. So I can only debug 32-bit Kernels. A guest 32-bit Kernel would not solve this problem.
    Thank you very much for your answer anyway,
    Leandro.
  • Hello,
    The software stacks that are provided as part of the Linaro ARM Platforms releases only ship with 64-bit kernels.
    Those 64-bit kernels do, however, boot at EL2 so have access to KVM with full architectural virtualization extensions; perhaps you could use KVM on the 64-bit kernel to host a 32-bit guest kernel?
    Regards,
    Ash
    Edit: Are you just trying to run a 32-bit application? If so, would compiling the kernel with multiarch support not suffice? You may need to compile the application statically though, or get a userspace with multiarch libs.
