CCN-508 as OCM(on-chip-memory)
Former Member
Former Member
Hi ARM experts,
We need to know in LX2160A cortex A72 from NXP how to put the CCM-508 as OCM, below are the thing we found until now but we need help in how to implemented in c code
Details
1 Configure CCN-508 registers in Trusted Firmware-A (ATF)
ARM CoreLink CCN-508 Cache Coherent Network
The CoreLink CCN-508 is a cache coherent interconnect that includes HN-F nodes (for memory) and RN-F/I/S (requesting nodes).
It supports a System Level Cache (SLC), often implemented using the HN-F’s local cache resources.
Register Configuration
`POR_HNF_CFG_CTL` (one per HN-F node):
The following bits control OCM behavior:
`hnf_ocm_en` = 1: Enables OCM mode for the HN-F node.
`hnf_ocm_allways_en` = 1: Treat entire node region as OCM
Where to modify the source
NXP fork of Arm ATF
See file: soc.c
function: soc_interconnect_config
2 Reserve and Map OCM as Physical Memory
Reserve a contiguous region of physical memory address space corresponding to the size of the OCM (e.g., 2 MB, 4 MB).
Match this region with the total size of enabled SLC/OCM blocks.
Align to the required cache block granularity (e.g., 512KB, 1MB).
3 Set MMU Page Table Attributes
Configure the A72 MMU page tables to map the OCM region using appropriate memory attributes:
Memory type: Normal memory
Inner/Outer Non-Cacheable
Inner Shareable
Read/Write, Execute/Non-execute as needed
4 Declare SRAM Region in Linux Device Tree
To prevent the Linux kernel from using the OCM region as general-purpose memory declare the reserved region in the device tree (DTS) and optionally expose as a device (/dev/ocm_sram) or assign to specific kernel modules
Example:
ocm_sram: sram@80000000 {
    compatible = "mmio-sram";
    reg = <0x0 0x80000000 0x0 0x200000>; // base addr + size
    no-map;
May you please help with some c code examples?
Thanks ind advance.
