I'm trying to fully uninstall uVision. I've been able to uninstall all "modules" with the normal procedure. However I was not able to fully remove uVision.
There is still the following folders under "C:\Keil_v5" :
- Backup.001
- license_terms
- UV4
Moreover, the UV4 folder and Backup.001 folder contains the full uVision.
I was not able to locate a unistall.exe nor did the program appeared in the control painel's list.
How should I procede to fully remove uVision?
Those are additional folders, not part of the default installation. They can safely be deleted if you are doing a full uninstall.
