Following the getting started example here: https://learn.arm.com/learning-paths/microcontrollers/asm/setup/ I cannot get past the Configure the FVP section. The instruction to browse for the FVP provided with the MDK at Keil_v5/ARM/FVP/MPS2_Cortex-M/FVP_MPS2_Cortex-M4_MDK.exe is not possible because the FVP sub folder doesn't appear to have been installed with the MDK Lite installation file.
Which version of the tools do you have installed? The latest is 5.38a.
5.38.0.0. Not sure if this is later than 5.38a.
It is the Lite version however. Perhaps the lite version doesn't have the FVP tools??
Thanks for the response anyway.
Hi again,
I double checked, and in fact this folder was removed after the 5.37 release (mine was still present from a previous install).https://developer.arm.com/documentation/107778/5-38a/MDK-Version-5-37
You can now find the FVPs, renamed as VHT* (Virtual Hardware Targets) in the VHT folder.
I will update the learning path content as soon as possible. Thank you for letting us know!
Ronan thank you for the information. I manged to find the VHT folder and move forward.
FYI, I've updated the Learning Path:https://learn.arm.com/learning-paths/microcontrollers/asm/setup/
