GICD_IGRPMODR[0] register read as 0
I am configuring the GICD_IGRPMODR[0] with a 0X3FFFFFFF value. Sometimes value is read as 0 sometimes it is 0x3FFFFFFF.
The value of GICD_CTLR is 0x30.
1) Can you please tell me why this register behaves differently?
2) In GIC Spec
     https://developer.arm.com/documentation/ihi0069/latest/
     Page 567 title: Accessing the GICD_IGRPMODR
     There are 2 statements that sound contradictory
      A) When GICD_CTLR.ARE_S==0 or GICD_CTLR.DS==1, the GICD_IGRPMODR<n> registers are RES0.
     B) When affinity routing is enabled for the Secure state, GICD_IGRPMODR0 is RES0 and equivalent functionality is proved by GICR_IGRPMODR0.
      When GICD_IGRPMODR[0] register marked as RES0? When ARE_S=0 or ARE_S=1. In our case DS =0 always
3) What is the value of RES0? Is there any difference between RES and RES0?
  • 1) Can you please tell me why this register behaves differently?
    There's a few reasons why GICD_IGRPMODn might read as 0 when it in reality it has a different value.
    • If DS is 0, then GICD_IGRPMODn is RAZ/WI (read as zero, ignore writes) to all Non-secure accesses.  Note, it's the security of the access that matters, not which state the access came from.  When in Non-secure state, all accesses are Non-secure.  When in Secure state, you can generate both Secure AND Non-secure accesses (controlled by the NS bits in the translation tables)
    • If DS is 1, or the ARE bits are 0, the register is RES0.
    It could perhaps be explained better, but it's not a contradiction.
    The ARE bits control whether the GIC is in legacy/GICv2 mode (ARE=0 means legacy).
    When ARE_S=0, ALL the GICD_IGRPMODR<n> registers are RES0, because these registers didn't exist in GICv2.
    When ARE_S=1, specifically GICD_IGRPMODR0 is RES0.  This is because GICD_IGRPMODR0 covers INTIDs 0..31, and in GICv3 those INTIDs are controlled via the per-PE GICR registers.
    RES0 means "Reserved, Should be Zero or Preserved".  For the full definition of RES0 see the Glossary in the Arm Architecture Reference Manual.
  • Thanks, Mr.  for the details.
    I checked the address of the register in the code. The offset of the register is 0x0D04 meanings its GICD_IGRPMODR[1] register.
    While accessing GICD_IGRPMODR[1], Our system is in a secure state, and the DS = 0, ARE_s = 1, ARE_NS=1(ie  GICD_CTLR = 0x30)
    1) Does Any other configuration affect the GICD_IGRPMODR[1] to become RES0?
    2) Any idea, How to check what is access mode( Non-secure accesses, and secure access) while accessing the register
    Thank you in advance
